i had a good look around sv, and could find no instructions.
they can be bought under a few brands.
Also, once the hub had finally siezed and the wheel was pretty much unusable, i took a hammer to it. The bearings appear to be press fitted, but the shape of the internals means that once they are seated, you cant get a drift behind them to get them out.
Do you know how in a hope freehub, you have to shift a spacer to one side, to be able to get the drift behind the bearings?
well in these, the spacer in the middle is fixed, a part of the shell, so cant be removed.
not that my hammer and I could work out at least.
on the plus side, the flange measurements are close enough that i bought a new hope pro2 (QR) and transplanted the rim and old spokes across directly
Sorry!
