On Monday, I bought another retrobike, a Proflex 753. 8)
It has 7 speed DX shifters. The rear (right) shifter will only access the highest 5 gears though. 😕
The rear derailleur moves smoothly; no hangup or anything. Its not limit screws, I can move the rear derailleur onto the biggest 2 cogs by hand. The cable runs freely in the housing; I took out the cable, wiped it down, and ran some WD40 through the last 2 pieces of housing to clean out any crud.
So I took the cover off of the front shifter, and it seems sticky inside. It looks like whatever oil, grease, or other lube was in the has gone all gummy over the past 21 years. I sprayed some WD40 on it hoping that it would act as a solvent and free things up. it did a bit, but I need something better. I’m reluctant to try something real aggressive like carb or brake cleaner as I’m not sure what materials everything is made out of.
What should I use?
