Stems and steerers....
[Closed] Stems and steerers...
[#3665942]
So we have 1.125", 1.125"-1.5" tapered and 1.5" fork steerers - am I imagining things or are stems only sized by handlebar diameter (25.4 or 31.8) and length and rise? If so, how do they fit the different steerer tube diameters?
Posted : 11/02/2012 1:44 am
For a 1 1/8th steerer you buy a 1 1/8th stem.
for a 1.5" steerer you buy a 1.5" stem
For a tapered steerer you still buy a 1 1/8th stem as it obviously tapers from 1.5" at the bottom to 1 1/8th at the top.
You then have to choose a model with the correct size handlebar clamp or use a shim.
Posted : 11/02/2012 1:48 am
