Best to ask the local engineering company to make you one up 😉 piece of cake with the right kit and skill!
I used a friction fit as mine was fine without the extension, this just made sure I could tighten the top clamp bolt correctly and not cause the stem to fracture by pinching the clamp till the gap closed.
Machine screws are not a good solution, epoxy glue is fine but you need to do it properly with a small clearance for the glue layer and the surfaces must be prepared properly etc.
If in doubt, dont.
