Stans ZTR Crest Rim...
[Closed] Stans ZTR Crest Rims
[#3977740]
What tyres fit reasonably easily to this rim?
Posted : 15/05/2012 4:18 pm
Search forum history you'll find masses on this, it's been done several times.
Me, tubeless: Bontrager Mud X, Schwalbe Rocket Ron Evo, '11 version I think.
Seek, you shall find.
Posted : 15/05/2012 4:52 pm
XR4 & Ignitor went on fine for me.
Posted : 15/05/2012 4:58 pm
Cheers for that.I'll try the Bontys.
Posted : 15/05/2012 5:30 pm
My Bonty mud X's were a pain in the ass. I now have folding Conti Mountain King Protection black chills. They went on pretty good. 2.4 on front 2.2 on rear. Great tyre by the way.
Posted : 15/05/2012 5:40 pm
 JRTG
As above done billions of times but not sure why tbh! Yes a little tight but nothing compared to the old ritchey ocb rims phewy!! (90's reto comment...) Plenty of tips on line to get tight tyres on and off, just takes a little technique and tyre levers will be a thing of the past.
Posted : 15/05/2012 5:56 pm
Bear in mind whatever you use needs to be loose enough that you can get it off, on the trail, and then on again with a tube in, in the event of a tyre tear or flat the goo won't plug. I've had this happen.
Posted : 15/05/2012 6:48 pm
 IA
True story!
Posted : 15/05/2012 6:52 pm
Crests, you say?
/Makes that sucking in sound that a mechanic at a car garage makes right after lifting up the bonnet...
Posted : 15/05/2012 7:14 pm
Maxxis Advantage's go on themselves. A blind monkey with no thumbs could get them on & off.
[i]/Makes that sucking in sound that a mechanic at a car garage makes right after lifting up the bonnet...[/i]
Why? Had an issue with them?
Posted : 15/05/2012 7:36 pm
Specialized 2Bliss tyres seat and inflate far more easily on my Crest rims than they do my Flows!
Posted : 15/05/2012 7:47 pm
 br
Every tyre I've tried has pretty much gone on every rim I needed it to, and 2 sets of Crests here running tubeless - no problems.
Posted : 15/05/2012 8:00 pm
[b]esselgruntfuttock: [/b]Always! - I host regular wrestling matches between me, Stans and Schwalbe. I still rate the Crests though - very strong for the weight.
Posted : 15/05/2012 8:06 pm
Nobby Nics and Racing Ralph are a bit of a nightmare to get on. High Rollers and Advantage no problems, I havent tried any others
Posted : 15/05/2012 8:21 pm
