The hope SS hub now has a needle bearing.
– Upgrade kit for your Hope Pro 2 Trials hub, exclusive to TartyBikes (as of March 2010!).
– Converts your older Pro 2 Trials hub to the newer needle-bearing and single cartridge bearing design freehub body or can be used as a direct replacement for your newer Pro 2 Trials model.
– Needle bearing design is a massive 7 times stronger compared to the old bearing design!
– Tough steel construction stops sprockets from digging into the freehub body.
– Available with or without pawls and springs.
– Comes complete with new end cap and spacer.
– Weight: 162g (Including end cap, spacer, pawls and springs)
