OK; a 2:1 ratio (eg. 32:16) is the starting point for a 26er. Because a 29er has a bigger wheel, each pedal turn will take you further for the same gear ratio, making the gear proportionally higher overall by 29/26 (because circumference is proportional to diam – with me so far)
Hence instead of 2:1, you want something slightly less as a starting point for a 29er.
32:16 x 26 = 52
32:18 x 29 = 51.6
or for you with a 36T front:
36:20 x 29 = 52.2
Now, if you want something slightly easier, because you live in a hilly area, or are a spinnier rider, then up the rear or reduce the front accordingly (not sure how easily available 21 or 22T rears are though). I doubt you want much harder unless you live somewhere properly flat like Thetford.
FWIW i run 34:18 x 29 = 54.7 but I have got a wonky ring on the front which is a whole different question
http://singletrackworld.com/forum/topic/elliptical-single-speed-chainrings
