Not sure how this happened but as I was installing my new SRAM GX derraileur the hangar bolt somehow came out. All the component parts seem to be OK and not damaged with no missing parts but I am struggling to put the thing back together again. It’s quite simple really, there is the bolt which you slide through the hole in the Derraileur, then there is a wave spring, the shaped watch thing that locates against your hangar and B-Screw, then a small split washer (not circlip) that locates into a small groove to hold it all together. The thing is after a good amount of trying and lots of swearing I can’t get the clip into the groove.
Anyone done this and have any handy tips or tricks? It is a sparable part so intended to be disassembled and re-assembled, but i’m damned if I can do it so far.
Cheers.
