Hi
Trying to swap out a crankset on a bike but having problems. I currently have an X1 crankset with a GXP BB. I’m trying to fit a Force CX1 crankset using the same BB. However, when I tighten the crank bolt (to fit the non drive side arm), it compresses the inside of the drive side spider and the mounting bolts against the outside edge of the BB causing it to lock in place. So it’s not rotating on the bearing. Hopefully that explanation makes sense.
So what’s the deal? Is there supposed to be some sort of spacer to keep the spider and BB shell apart? Or is there a different type of GXP BB that is needed (given that X1 is an MTB groupset and CX1 is a road groupset)?
Any ideas?
I’ve tried this using both a Race Face direct mount ring as well as with the original spider that came with the CX1 cranks.
