SQL help wanted ple...
[Closed] SQL help wanted please
 mrmo
[#3769343]
Trying to do something in SQL, SSRS
I will try and explain,
i have some customers and i need to group to show how many new accounts we have in a month and how many lapsing accounts.
I can get the max and min invoice dates and can show for any given month how many customers are new or lapsing, but the problem i am having is seeing how i can group this month on month? so that i can then plot a graph showing the trend.
Any one able to offer a pointer?
Posted : 13/03/2012 2:38 pm
Use a group by clause as follows ?
group by (datename ( year, invoice_date_column) + datename ( month, invoice_date_column))
where invoice_date_column is the column on your table containing the date you're interested in ?
disclaimer: not a SQL server bod, never used it 🙂
Posted : 13/03/2012 2:49 pm
Check out this [url= http://improve.dk/archive/2006/12/13/sql-server-datetime-rounding-made-easy.aspx ]guide[/url] where they use date use month
Also not a SQL Server user
Posted : 13/03/2012 2:50 pm
 mrmo
not quite what i am getting at.
In month one i need to know the count of accounts whose min purchase date falls between 0 and 1 month ago, i also need the number of accounts whose max purchase date is between 4 and 5 months ago.
In month two i need to know the count of accounts whose min purchase date falls between 1 and 2 month ago, i also need the number of accounts whose max purchase date is between 5 and 6 months ago.
repeat.
Then plot these numbers on a graph.
Posted : 13/03/2012 3:24 pm
Difficult to say from the information given, but I think you'll be wanting to use datediff rather than max and min
Posted : 13/03/2012 3:47 pm
You should be able to achieve that with a Common Table Expression (CTE) Query.
Google search for "SQL CTE". The first link returned is the MSDN page with a good example.
Posted : 13/03/2012 4:14 pm
Would need some idea of your data structure to give detailed help but whatever you do that requirement is going to leave you with a right old mess of a query unless your data structures are tailored for it
Posted : 13/03/2012 4:27 pm
yup just post up your ip address and sa password and we'll do the rest
Posted : 13/03/2012 4:49 pm
I guess your users table has some fields like joined_date and left_date.
So just count and groupby month on joined_date for new customers.
And same on left_date for lapsed?
If you don't have fields analogous to those then what fields do you have to work it out?
Posted : 13/03/2012 5:05 pm
Not sure about server SQL but I used Year, Switch and DatePart to create a Year, Month grouping to then follow with Count.
So:
SELECT Year(LRPDate) AS [Year], Switch(DatePart('m',LRPDate)=1,"01 January",DatePart('m',LRPDate)=2,"02 February"... ..., Count(*)
Group By Year etc etc
Posted : 13/03/2012 5:22 pm
 mrmo
all i need is in the single sales table,
The plan is count of accounts grouped by first sale date. That is the easy bit.
the hard bit is i need to look at the data month by month and ignore everything that is more recent.
So if we start in February, how many new customers were there, a new customer is one who bought in february or january.
Then i need to show the situation in January, ie in January how many new customers were there, ie whose first purchase was in January or December.
Then repeat for December.....
I then need to do the same thing based on the last sale date.
Posted : 13/03/2012 5:28 pm
What I wrote would seem to fit what you need. I guess you could have already run a separate query to group the preceding months together...
Posted : 13/03/2012 5:38 pm
