Viewing 5 posts - 1 through 5 (of 5 total)
  • Spongy SLX lever.
  • andycs
    Lever started pulling back to bar, although brake still works fine. Cable tied lever to bar overnight and lever was perfect. However despite not being used, lever now pulls back to bar again. No leaks and enough fluid in system. Any ideas what the problem might be?
    dirk_pumpa
    you’ve got air in the system.
    edd
    Probably needs a bleed, pay particular attention to steps 8 and 9 in the instructions (linked below):
    http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Deore-XT/SI_0116A/SI-0116A-001-00-Eng_v1_m56577569830746864.pdf
    shortcut
    bleed it!
    andycs
    Will give it a bleed. Would fluid not be leaking out if air was getting in?
The topic ‘Spongy SLX lever.’ is closed to new replies.
