Spesh E150 Fork Ada...
[Closed] Spesh E150 Fork Adapters to Quick Release or 20mm/15mm axle
[#3376475]
Anyone know if there is such a thing?
Posted : 21/11/2011 9:49 pm
There isn't such a thing - I looked into having one made at a local engineering firm and we came up with a decent design, but I ended up selling the forks before any testers were made so it never happened. If I remember correctly it was fairly simple.
Its a shame, as the forks were superb, but theres 2 options
a) buy (if you can find a set) some roval traverse? wheels - there a certain year they will fit and are supposed to be pretty good
b) have the origiinal hub built onto a different rim.
Posted : 22/11/2011 12:48 am
Hi,
I think you will find that a suitable adaptor should be available for at least the older traverse wheels. I have a few sets and all came with 9,20 and the 25mm adaptors (the one you are after). I think they changed the hubs on the traverse wheels recently (2010 or 2011), so look for the older wheels and you should be able to get an adaptor. I am not sure if they do a 25mm adaptor for the newer traverse wheels.
HTH
Simone
Posted : 22/11/2011 1:04 am
Cheers guys, I'll have a look at the rovals....
Posted : 24/11/2011 12:39 am
I recently picked up a second hub on ebay, to build into a new wheel after suffering the same problem fieldy. Good luck with the quest.
Posted : 24/11/2011 1:03 am
Industry9 also make wheels/hubs for the E150.
Posted : 24/11/2011 1:06 am
anyone got a spare hub??
Posted : 15/02/2012 10:59 pm
I believe certain dt Swiss hubs are fairly easily adapted. Also I bought one of the hubs from Specialized only 4 months ago...
Posted : 15/02/2012 11:11 pm
um, i'd be after a adaptor too.
Posted : 15/02/2012 11:24 pm
there must be some engineering genius on here who could do it???
Posted : 16/02/2012 12:01 am
 bol
I've got a spare 25mm adapter for the Roval Traversee wheels - and the wheels to fit them to if you'd like them? The last of my 26" bits. Drop me an email if you're interested.
Posted : 16/02/2012 7:24 am
Bol
Ygm
Posted : 16/02/2012 12:49 pm
