The shock is the same length, but I don't think the rear end of my Elite frame has the necessary fixing points for the 'Brain' part of the shock.
I know for sure that the Expert has an extra 'cable' mount at the top of the non-drive side with a little plastic bit that secures the hose between the Brain & the shock, that the Elite doesn't have.
So, at a guess you'd need a new rear end to fix the Brain in place.
I tried the Brain and while it seemed to do what it should, I don't miss it on the Elite. It made a subtle clunk through the rear end everytime it activated that felt like I'd just hit the rear rim into a root. I'm sure you'd get used to it, but I found it quite annoying….
