I have some 08 E150's and I really rate them> they take a bit of experimentation to get them set up and small impact sensitivity was poor until I had them sorted at TF Tuned. They're at least as stiff as 36's and imo the travel adjust is far superior to the talas system. I rode a 2009 with the 150mm float 32's on it and it was awful by comparison. The forks just didn't track anywhere near as well.
The only drawback I have experienced to date is that you're pretty much tied into the spesh 25 mm front hub unless you're prepared to spend a lot of money on an industry 9 25mm or similar.
Having said all this (and seen your other post), I thought the Pitch was pretty much the same geo and BB height as the enduro? (although I haven't suffered much with pedal strikes – are you running the right shock pressure/ considered running a taller/wider tyre?)
