I picked up a second hand 2011 Enduro frame that came with a Fox RP23 shock a couple of months ago. The frame fits me really well and feels great on steeper stuff compared to the zesty I had previously.
I’m not sure if the shock has been serviced before, and I’ve noticed that when you let the air out you also get a bit of green gunk coming out of the valve, is this normal?
The shock also seems to blow through most of its travel with ease, just unweighting and weighting, although I never feel it bottoming out on drops/rock gardens. I run around 25% sag. I find it hard to get any pump on jumps, the shock just seems to soak it all up. Also pedalling seems a bit inefficient, but I can put up with that upto a point.
The pro pedal also seems to make very little difference, even in the firmest setting?
Is this to be expected with a 160mm rear end, or the suspension design of this frame?
Is it worth getting the shock serviced (around £100), or tuned?
Or if I’m spending would it be better to upgrade the shock for something else?
