Viewing 3 posts - 1 through 3 (of 3 total)
  • Specialised enduro 2015 pivot bearing
  • crispy1980
    Hi all, does anyone have a link or a suggestion for how the main pivot bearings are removed from my speed enduro 2015? The ones directly above the bottom bracket. There appears to be a spacer tube between the two bearings? Cheers
    clockarockin
    The best way is using a blind bearing puller like the one below. These can be pricey though so in my case I took my frame to an LBS and they pulled them both for a fiver I think.
    crispy1980
    OK, thought that might be the case, lbs it is then, cherrs
The topic ‘Specialised enduro 2015 pivot bearing’ is closed to new replies.
