Specalized Front Hu...
[Closed] Specalized Front Hub Bearing Size
 Chew
[#1970892]
I have to replace the cartridge bearings in my specalized from hub.
Anyone know what size replacement i'll need?
Its the one with the bolt through axel, rather than the usual quick release version.
Posted : 08/09/2010 11:02 am
 cp
I imagine there's umpteen varities of 20mm axled spesh front hubs. If you dissasemble the hub, the number should either be laser marked onto the bearing outer or embossed on the seal.
Posted : 08/09/2010 11:40 am
Possibly [url= http://www.rushcycles.co.uk/products.php?plid=m49b1s466p3690&rs=gb ]these[/url], although read the small print at the bottom of the page about Stout hubs varying from year to year. They recommend getting the bearing code off the old bearing.
Posted : 08/09/2010 12:27 pm
When you said "bolt through axle", I was presuming you have the DT Swiss 9mm bolt-thru skewers. If they're 20mm hubs, the bearing size may be 6804-2RS but, again, check the old ones before you buy.
Posted : 08/09/2010 12:32 pm
