Viewing 3 posts - 1 through 3 (of 3 total)
  • Spacers to make an old wheel fit a frame/fork
  • tpbiker
    Probably a daft question but…
    Putting together winter singlespeed and as the frame doesn’t have disk mounts i’m having to use an old set of rim brake wheels I had kicking about.
    Unfortunately the hubs are to narrow (although I’ve replaced the axle so that fits), can I just use bolts and washers as spacers to make it fit?
    cynic-al
    I don’t understand…firstly all mtbs from 1990 have the same spacing for QR hubs, secondly I can see how washers would make spacers, but bolts?
    Though all you need to make up any space is a washer or similar, yes, and make sure the axle is engaging in the dropout.
    acehtn
    Will assume a typo bolts=nuts 🙂
    Got any old cup and cone axle washer’s/spacers ? i used them with inboard chaintugs to space out a 700c wheel into a KM frame.
    Did see an awful death trap job where the owner had respaced a free wheel hub to run a single speed only, couple inch’s of spacers and washer’s.
    It can be done safely.
The topic ‘Spacers to make an old wheel fit a frame/fork’ is closed to new replies.
