Well, it seems I have another set of forks to send back with a creaky crown – that’s 2xRS, 1xFox, and 1xMarzocchi (but they went back twice) in the last 6 years – dunno what I do to them cos I’m a strictly wheels-on-the-ground rider. Maybe I brake too much.
These ones should still be warranty jobs, but I’m getting a bit fed up with it. Fox F120 RL this time.
Options are –
send these back and wait for warranty and just refit them.
nab a set of older Marz Shiver SC 100mm forks which are available – cheap, but I’ll need a new front hub, and it’ll add some weight
Buy something else and see how long they last
fit rigid forks and be done with it.
Is anyone running rigid forks on a soul? If so, what axle-to-crown length are you using? Would I be better off with rigid 29er forks with a 26″ wheel to keep the geometry about the same?
Failing that, what forks could anyone recommend that are fairly light, but don’t have a crown made of cheese.
Depending on the outcome, there may be a minty-mint set of F120 RLs up for sale soon with new crown assembly and freshly serviced. Oh, and yes, they’ve had the lift-the-seals service every 15 hours. Ish.
