And i cant work out how.
I bought an old set of dual position 150mm revs second hand. They came with lock out which i hated so following a bit of online googling i removed the damper, unhooked the wee spring that holds the damper closed and voila, i thought i had a set of revs i could manually change from locked out to open with the old top cap.
Now, they seem to either be fully locked out or as near as. They just seem to ramp up and compress after about 40mm.
Online i found the manual that states they need 134mm of 5wt fluid in the damper side. Yep, that doesnt work.
Apart from buying a proper damper i am not sure what to do next.
Ideas. Oh and yep i knew i was fiddling and it could all go wrong 8O. And it has.
