sonos vs squeezebox
[Closed] sonos vs squeezebox
yep, ill certainly keep at it mate 🙂 technologys great innit 🙂 ill just update on my thoughts this morning after a nights sleep on it.
ive been thinking about what im doing now against a squeeze/sonos system. squeezebox will take music from a nas/laptop using its remote, utilising its own server software and sending it to amp.
ive just played an mp3 from my phone (so next step will be rip cd to laptop and try and play it) on my tv using my phone as remote and can play through my speakers.
thoughts are..... has my tv now replaced the squeezebox as the middle man? as digital music is just a series of 1's and 0's, is the sound quality exactly the same using tv rather than squeeze? or do they travel through different cables to different input (av?) on amp and lose quality?
as far as interfaces go, the tv showed what track was playing, same as a squeezebox would but bigger. maybe it wont show album art, but not too fussed.
small problem that should iron out ok, my phone found my wifes laptop on its search and could access her files, but didnt find mine. something to do with homegroups which i dont understand. ill look into that.
i still think im going to hit a limitation somewhere thatll mean i still end up buying a squeezebox, but for now its looking promising.
at work for a few days now so not as much time to play, but ill get a chance tonight maybe 🙂
Posted : 31/12/2011 7:26 am
For me, the squeezything is useful as I have a good stereo (and spare decent audio cable for it), and I wanted to play my music over that rather than some other stand-alone device, or relying on the TV being on to play it.
Posted : 31/12/2011 1:32 pm
All cables should be equal, but if you are sending a digital stream over a poorly shielded coaxial cable then it could pick up some interference.
The key determinant of the sound quality at the end of the day will be the speakers and amp that you are playing the music through.
At some point the 1s and 0s will have to be converted into an analogue signal. The quality and price of the digital to analogue converters (DAC) varies enormously.
In terms of overall sound I remember reading a good rule of thumb for what the sound is like is 60% speakers, 30% amplifier and 10% DAC.
Posted : 31/12/2011 3:58 pm
dave, i understand that, as im struggling a bit with the phone to see my laptop, and whether mine and my wifes laptops need to be part of a workgroup to be seen. dont really understand them. didnt get chance to experiment last night, but ill be on it again tonight 🙂
but your point is exactly the same reason i think ill end up getting one, unless i find an easy way of doing this the tv way.
ho hum, thats good to hear as i got some decent floor standing mordaunt short spakers and an arcam amp. quick question about the DAC. at what point does it get converted? is the squeezebox a DAC, or does it 'contain' a DAC? and same for tv? does this convert digital to analogue itself then?
cheers
Posted : 01/01/2012 7:18 am
Squeezebox has a dac, so both audio and digital out.
If you keep an eye on Logitech's website you may get a steal on the blemished box section.
EDIT
Hmmm I think the source still has importance - dac and psu. Both likely to be way better in an audio WiFi player than a tv but still capable of improvement. Back in the day do equal spend was suggested for source/amp/speakers (with enough for cabling and support)
Posted : 01/01/2012 7:38 am
Cynic-al is absolutely right, the source is not only important but critical. No matter how good your speakers and amp are they are completely dependant on the information they receive. Try it for yourself. Rip a Track off a CD at 128kbits/s and then the same as WAV or FLAC. If you have even a basic HI-Fi system set up correctly the difference will blow you away. Amp and speakers will still provide lots of power and presentation but data gives the accuracy.
The key to any music system is balance, both in terms or performance and investment.
Posted : 01/01/2012 8:19 am
Sorry, I should have said that the 60:30:10 rule applies to systems that are reasonably well balanced in the first place.
If the system is not well balanced then the old rule of garbage in garbage out will apply.
cynic-al is right about the squeezebox having a dac and from what I have read it performs quite well.
Posted : 01/01/2012 11:58 am
Anybody else use Vortexbox? I'm currently ripping my CD collection in FLAC format so I have a Gold Copy using an old laptop that I've installed Vortexbox on. Very easy process, pop in a CD then Vortexbox downloads track information, cover art etc and ejects the CD when finished.
Also acts as a NAS and best of all is free.
Posted : 01/01/2012 12:30 pm
Just thought I'd add my experiences, I have a Squeezebox set-up which consists of a Touch, a Classic, a Radio and 3 Booms.
I run the Squeezebox server on a QNAP 4 Bay NAS which is based on a dual core Intel Atom chip.
I have all my music ripped to FLAC and stream it wireless to most of the players.
I can't really fault the setup, the NAS makes a massive difference as I have run the server on lower spec NAS devices and it did struggle at times.
The QNAP has easy to install software "packages" and the Squeezebox server is available as one, so installation is as simple as a couple of mouse clicks.
I've played different songs on each player or even sync'd them all together (a simple menu option) and had them all playing the same songs around the house, and in the garden!
As has been mentioned some people are put off by the Squeezebox set-up because it can seem a bit complicated as it is so customisable.
I love my set-up and wouldn't change it for anything else.
Posted : 01/01/2012 12:59 pm
Spent yesterday evening at a Sonos equipped house.
We came up against its limits (for me at least) in that it wouldn't play from youtube, or anything else that it didn't 'know', wheras from my simple pc plugged into hifi approach I can listen to anything. Hopefully the TV centered hub thing would retain this flexibility.
I know this is horrible from an audio point of view, but sound quality is largely irrelevant in my case, due to playing guitar in punk bands and tearing round on noisy motorbikes in my youth...
Posted : 01/01/2012 1:10 pm
yup, i can understand that, as the '1s and 0s' will be worse quality on an mp3 than a flac, but how would the tv compare to the squeezebox both playing flac?
i guess the answer is to try it, but works getting in my way at the moment 🙂 thursdays my next day off to try things, so until then ill just keep reading up on it.
flapjack, not toooo bothered about being able to access youtube on whatever system i go for, but am i right in assuming if ive got the 'phone/tv/laptop' setup, my laptop could play youtube through the telly?
pembo, never heard of vortexbox, so ill check that out.
cynic-al, you say the SB has a DAC. does the tv too? and is it a case of a DAC is a DAC is a DAC? or are some better than others?
thanks
Posted : 02/01/2012 7:27 am
Any device that plays digital files will have a DAC, more audio centric ones will have better ones and deliver superior playback. A quick correction on your terminology to help understanding. 1's and 0's don't get better or worse, that would be impossible, you simply have more of them when ripping to a supirior the audio format. That's why (for example) a track ripped to 128kbits/s mp3 may be around 1Mb in size whereas ripped to FLAC would be say 5Mb or so. Lots more 1's and 0's describing the music so bigger file.
I think you'll struggle to find a TV that supports playback of FLAC. Not something I'm aware of but could be wrong.
Posted : 02/01/2012 9:03 am
This TV thing got me thinking. If you're happy using your TV as your GUI (sorry, Grapical User Interface) then you could consider such devices as Boxee and Apple TV - I'm aware of your dislike for Apple but Apple TV has a pretty easy user interface and includes Internet radio (and YouTube Flap_jack). Not as fast as Sonos and check audio support but will be heaps better than using a TV. Only £99.
I still advocate Sonos and Squeezebox as they are much, much better for music, but this would be viable and brings quite a bit of video fun to the party too. Even if you added Sonos etc... at a later date you'd still have use for both so the investment is sound.
Posted : 02/01/2012 9:20 am
That's what shocked me about the Sonos system I saw was it's apparent prevention of what seemed like ordinary connectivity. If you've not got a fancy box in the way I guess you can do anything (guessing though - I don't have a modern telly yet).
Good luck.
Posted : 02/01/2012 9:23 am
just thought id quickly rip a cd to flac and try and find it on tv, but..... ive just found out that windows media player doesnt do this. i googled it and seen a few programs mentioned, but all seem to say i need to instal plug-ins :-/
whats the general concensus of opinion on here for ripping to flac? what do you use?
thanks
Posted : 02/01/2012 10:04 pm
http://www.exactaudiocopy.de/
This is what I have seen recommended on a few hi-fi forums that I visit.
Posted : 02/01/2012 10:09 pm
thanks mate, just downloaded it now and am having a go at converting a cd to flac. bit baffled by it but have just sort of gone along with their own settings. couldnt see where to convert to flac but a quick google showed i have to convert to wav, then on to flac. hopefully ill get it figured out and the rest will be easier.
ta
Posted : 02/01/2012 11:06 pm
Not Sonos or NAS based but for boosting an iPod/iPad/Android device playing mp3's, Spotify, internet radio (Radio Paradise) in a kitchen or other 'non-Hifi' room I can really recommend the Creative bluetooth speakers e.g. D100. It's a doddle to connect, decent sound, runs on 4 x AA or mains. It's been brill over xmas playing tunes whilst following recipes on the iPad.
Posted : 02/01/2012 11:12 pm
itunes rips lossless...AACC or something?
EDIT and what lossless format you use and how you rip it are irrelevant.
Posted : 02/01/2012 11:16 pm
I don't see how any 10:30:60 system can be balanced.
sadexpunk - Member
I dunno about any TV having a DAC - I ghuess it must do as it produces sound from digital signal. Bound to sound crap tho.
Some DACs are better than others - a whole industry is based on it! I expect noise can be introduced through the digital signal also.
Posted : 02/01/2012 11:22 pm
 mjb
Why not go the whole hog and and build your own HTPC. Get a small form factor PC running something like XBMC or windows media centre and attach it to the back of your TV with a big NAS box to store all your music, films etc. Connect the audio to your amp (you could add a stand alone DAC for better quality) and the video to the TV and run your TV aerial/satellite feed through the PC. Then you have one interface from which you can listen to your music, play your films, look at photos, stream music/films from the internet, browse the internet, watch/record/timeslip TV. Control via remote or through your phone/laptop. Simple...
Posted : 03/01/2012 12:01 am
Simple..
dont understand that mate, so not too sure its the way to go for me. does it mean buying another pc? in which case the squeezebox is probably a better and more simpler option for me. i hear what youre saying about video too, but are you saying that it could all be controlled from phone?
ask1974 and cynic-al, i see your points about apple tv and itunes, but its become a bit of a mental thing with me now, i just dont want to use anything apple 🙂 i just gave my ipod classic away to someone for this reason and i spose itd be like admitting i should really not have done that 😀
thanks
Posted : 03/01/2012 7:13 am
I'm no apple proponent. Squeezebox will make you happy, it has done for me...sounds great, pretty easy to set up, controllable from your phone, and reasonably priced.
Posted : 03/01/2012 9:30 am
right, latest problem for me is.......ive ripped a cd to flac on my laptop, and im trying to 'find' the laptop through my phone. im using 'connected media' app. i can see my wifes laptop, and her files on my phone, but not mine. we're both connected to the same 'homegroup', but i dont really understand homegroups.
any ideas? (yes i know....just buy a squeezebox!) 😀
Posted : 03/01/2012 9:24 pm
 dobo
right click on my computer and properties and it should show workgroup which i assume is your homegroup.
the default i believe is WORKGROUP, some services require this to be the same on all machines on that local area network.
if you have a work laptop this will likey be different and would not recommend trying to change this, and you will probably find it wont work anyway.
i'm not familair with that app so cant help
dont forget to install subsonic on laptop/pc and your phone to see what can be done 🙂 it will transcode to all formats and bitrates, only downside is, its a web or app program only at the moment
Posted : 03/01/2012 9:58 pm
I gave up reading all the long replies but thought I'd add my 2p.
I have a decent hifi and wanted something that would plug into it and play my library of tunes as my CDs are all in storage elsewhere. Since my hifi has a great DAC in it, it made sense to have something just plugged into it, rather than a standalone device, or something that relies on a different machines DAC.
So I went with the Squeezebox Duet, which has a wifi remote (ie it doesn't have to be line of sight), and a receiver that plugs into the back of the hifi, through digital out or analogue through using its own built-in Wolfson DAC. I also have a spare netbook that I installed SB server on.
So if I just want to listen to BBC 6Music, I turn on the hifi and stream that through the SB. For digital music, the SB pulls it from the netbook and pumps it through the hifi.
It works well on the whole, and it's a heck of a lot less buggy than it used to be. There are fairly regular firmware updates that get pushed out, and they have helped with the stability, which was previously an issue. And there are a number of apps that you can add to the system, to support Spotify and so on. Internet radio functionality is also great, and if you want later to add more receivers (standalone or for other hifi units) you can, and control them all from the one remote.
Personally, I'd recommend that route, particularly since the Duet is available for cheap as it's discontinued; but I haven't explored the other options available.
Posted : 03/01/2012 10:15 pm
OT - Sadexpunk - Are you still living over Lincoln way?
If you are, bad news I'll be over there in a couple of months...
Posted : 03/01/2012 10:37 pm
dobo, just installed subsonic on laptop and phone. spent ages configuring laptop to run server. i keep getting firewall messages every few seconds even tho i 'remember my answer', ive followed instructions to set up the phone to talk to it, but it keeps failing to connect.
im not even sure what im sposed to get out of it even if i did connect it 🙂
its all got me pretty sure its just not worth the hassle. a squeezebox would just be so much easier. i just cant seem to access my laptop music on my phone firstly, to even try and send to a tv :-/ im ready to give up 🙁
i just found out the basic htc desire which my wife has doesnt support this anyway, so itd only be my phone able to be used as a remote.
as has been recommended already, ill just buy a squeezebox i think. im not technically minded enough to solve the problems im coming up against.
thanks everyone for your help. its much appreciated.
john - yes, still living here, altho shamefully i havent been riding for months now. sort of lost my mtb mojo and have been more into weights than cardio recently. the other lads i used to ride with just go road riding now which doesnt interest me, so im out of practice and fitness 🙂 always pleased to meet up for a beer tho 😀
Posted : 03/01/2012 11:09 pm
Click on my user name and drop me an email and I'll give you a shout.
Posted : 03/01/2012 11:12 pm
duets come up SH on fleabay but seem a 'mare to set up without the controller (which is supposed to have a dire battery life) - I have one I got and am not sure what to do with it!
Posted : 03/01/2012 11:24 pm
 mjb
Basically rather than buy a sonos or squeezebox make your own. They are both just basic PCs with good quality DACs in them. Why not buy a small PC ([url= http://www.shuttle.eu/products/ultra-small/xs35gt/overview/ ]for example[/url]) and use the TV as the screen. You'll just need some software like Windows Media Centre or [url= http://xbmc.org/about/ ]XBMC[/url].
Have you by any chance got windows media centre on your laptop already? If so you could plug the laptop into the stereo and try it out before spending any money on a dedicated machine. Later on if you are feeling adventurous you can start to include things like playing DVDs streaming videos/music, browsing the internet and recording TV.
... but are you saying that it could all be controlled from phone?
yep, there are quite a few media centre remote apps. Have a look at Remote Media Center and Remote Potato on the Android market as an example.
Posted : 04/01/2012 12:13 am
as far as that small pc, wouldnt that just cost the same (maybe more) than a squeezebox? or are you suggesting it for the versatility of vids and photos as well?
just had a look at windows media centre and pointed it towards my music folders. how do i connect it to amp? what leads to which connections? and are you saying those phone apps will 'find' my laptop running media centre and play my music through the amp without me touching laptop? i ask as my 'connected media' app cant find my laptop.
cheers
Posted : 04/01/2012 10:32 pm
Interesting stuff. I'm going through similar thought processes. My Blu ray player is a DLNA client and I've had it hooked up to both a PC and Mac using Windows Media player andiTunes/Twonky respectively. The biggest issue is for me the usability of the client. If picking music to play from a pretty big library is too much faff I won't bother. That's why the Apple TV and iPhone as a remote looks good.
Posted : 05/01/2012 9:51 am
mjb, just been following your link on that pc and reading up on it. i hadnt considered a 'media centre' pc as such, and im interested in it now. but..... it looks like it needs me to get separate drive/ memory etc and instal everything myself. am i right?
might be too fiddly for me to do, id prefer something that works out the box. can you advise me on this?
am i right in thinking this pc would be a box instead of a squeezebox, that would play flac to the same quality (good DAC?) yet also play vids, youtube, internet radio.....in fact everything im likely to need?
thanks
Posted : 05/01/2012 10:00 am
What're the advantages of having a separate media centre PC? I don't get the idea of having a box tucked away somewhere as a media server because I don't understand how you then rip CD's onto it quickly and easily.
I just leave my Mac on and can either access my entire library via Home Sharing on my iPhone (and hence each and every hi-fi or docking station) or via my DLNA client (the Blu Ray player) using Twonky Server which is plugged into my main stereo and TV.
Posted : 05/01/2012 10:47 am
could that also be read as 'whatre the advantages of a separate squeezebox?'? if youre happy with your mac being your media player then thats the same as me using my laptop isnt it? not fully sure i understand you.
i would be ripping cds to either the ickle pc or 'laptop to nas' and then using the ickle pc to stream to hifi. at least thats how im understanding it with my limited knowledge. happy to be put straight on this tho 🙂
Posted : 05/01/2012 11:36 am
I suppose so, yes. In my experience people are often naive of what their existing kit can do. Windows Media Player is a DLNA server (so no need for something like Twonky). Many modern TVs/Blu Ray players/Games consoles are DLNA clients so most people already have the kit to stream from their PC/Mac to at least their lounge. Unless you want multi-room streaming I'm not sure why you need Sonos and I don't really know much about Squeezebox.
My iPhone can access my entire iTunes library simply by turning on Home Sharing in iTunes provided I'm in wireless range. Nothing more than a couple of button clicks and my whole library can be played anywhere I can plug my iPhone in. Not really an audiophile solution, but pretty powerful. Like I said in a previous post, I believe THE most important thing is the client you use to browse and play your library. If that's a pain to use and find your music, you'll regret the money you've spent, so it's worth a demo if you can.
Posted : 05/01/2012 12:01 pm
I can stream music from my laptop to my Sony blu-ray player. Unfortunately, the sound quality isn't amazing, and the menu system on the Sony makes it difficult to access particular tracks. Presumably, Squeezebook would improve on this?
Posted : 05/01/2012 12:23 pm
Exactly. I have a Sony BD player and don't generally use the streaming because of this. Instead I use my iPhone as a client that I simply plug direct into my amp. However, for the OP it might be fine to work with what he's got as a cheap and cheerful start. Otherwise get to a decent shop, get a demo and find the system that gives you what you need, since it can get a bit mind-boggling focusing on the technical side.
Posted : 05/01/2012 12:29 pm
 mjb
First off I'm no expert in all this it's just something that I've been playing around with at home.
[i]as far as that small pc, wouldnt that just cost the same (maybe more) than a squeezebox? or are you suggesting it for the versatility of vids and photos as well?[/i]
Yes it would probably cost a bit more than the Squeezbox (but less than the Sonos) but my reasons are more to replace all the various boxes in my living room with one box and more importantly one interface whilst at the same time adding a bit more functionality like iPlayer and movie streaming. Don't get me wrong I like the look of the squeezebox touch and have been considering one for a while now as our stereo is in a separate room to the TV etc. so I'll need another interface anyway.
[i]just had a look at windows media centre and pointed it towards my music folders. how do i connect it to amp? what leads to which connections?[/i]
Depends on what connections you have on your laptop/amp. At the very least you could connect the headphone socket on the laptop to one of the pairs of RCA inputs (Aux or CD) on the amp.
[i]and are you saying those phone apps will 'find' my laptop running media centre and play my music through the amp without me touching laptop? i ask as my 'connected media' app cant find my laptop.[/i]
Yes although I have never tried them myself. I believe there are two parts to it though, an app for the phone and a small programme to run on your laptop. Have a read here for the info
http://www.remotepotato.com/about.aspx
[i]The biggest issue is for me the usability of the client. [/i]
Agreed, that's why I don't like Windows Media Centre. I'm currently trying out XBMC as I prefer the interface and it's supposed to be much faster.
[i]mjb, just been following your link on that pc and reading up on it. i hadnt considered a 'media centre' pc as such, and im interested in it now. but..... it looks like it needs me to get separate drive/ memory etc and instal everything myself. am i right?[/i]
Yep you'd need a hard drive(I'm considering a 60gb SSD to keep everything silent (~£80)), some memory (~£12), possibly a DVD/Blueray player, and an operating system (Linux is free). However, I believe that you can buy them with the parts already installed although you may be limited to certain drives etc.
[i]might be too fiddly for me to do, id prefer something that works out the box. can you advise me on this?[/i]
Pretty much any PC could be used as long as it can handle HD streaming and playback. Some manufacturers even label them as HTPCs although i don't know what software they use nor if they will do everything you want. Larger ones tend to be more versatile (you can fit extra cards like TV tuners internally, you could include the storage here instead of in a NAS) but I like the idea of this as it's cheap, small and quiet. Have a read of these articles to give you an idea of what people are doing with them
http://breden.org.uk/2010/09/22/shuttle-xs35gt-the-ultimate-silent-media-center-htpc/
http://lifehacker.com/5391308/build-a-silent-standalone-xbmc-media-center-on-the-cheap
[i]am i right in thinking this pc would be a box instead of a squeezebox,[/i]
Yes
[i]that would play flac to the same quality (good DAC?) yet also play vids, youtube, internet radio.....in fact everything im likely to need?[/i]
No the DAC won't be as good. Try connecting your laptop to the stereo and see how it sounds, if it's not good enough for you then you'd need to by a standalone DAC.
[i]yet also play vids, youtube, internet radio.....in fact everything im likely to need?[/i]
In theory yes, probably not straight out of the box though. I guess you could think of these as media centre software doing the core work and then lots of add ons being written by various people (some official some not) to do the more specialist work. Some things like accessing music and videos should be as simple as pointing the software to the right folder, some like youtube, iPlayer access might require installing a plugin and some like watching/recording live tv might require a fair bit more work and a few visits to the forums to get working. That's one of the reasons why I suggest you try things out on your laptop first to see if you can get it all working as you want without spending any money. Start with the basics and then add on various upgrades, you should be good at that being a mountain biker!
[i]What're the advantages of having a separate media centre PC? I don't get the idea of having a box tucked away somewhere as a media server because I don't understand how you then rip CD's onto it quickly and easily.[/i]
For me I want to replace my old sky box, noisy PVR and DVD player and also get access to iPlayer, 4OD etc, stream movies from Lovefilm and access movies and music on my NAS. I want to do this all with one cheap, small and quiet box through a single interface and so far I haven't found an off the shelf box that meets all these requirements. I'll rip CDs/DVDs using my laptop and store them on the NAS, the HTPC will access them from there, the plan is not to store anything on the HTPC except recorded TV.
Posted : 05/01/2012 12:42 pm
I've had a squeezebox for a couple of years and hardly used it. It does work but takes a while to rescan my itunes library (admittedly itunes may be the problem!). I recently bought an airport express and now can easily stream music from my macbook or iphone through my amp & speakers. You don't mention apple above so the squeezebox might work better for you. My pal has sonos and it is much slicker (and more ££).
Bit confused by this - your squeezebox doesn't do the rescanning, your music server does - the squeezebox just initiates it at your command, but you can set it to rescan each night and only re-scan new or changed files, which takes a few seconds rather than a few minutes.
I wanted a media centre but concluded that I don't want a big power hungry server machine running 24/7 just so that occasionally I could play some music in the kitchen or record a TV show, especially considering the cost of the individual music points required in each room too.
Posted : 05/01/2012 12:47 pm
except recorded TV.
Ah-ha. This is the bit I've managed without since iPlayer et al.
Posted : 05/01/2012 1:00 pm
my 2p.
I use Squeezebox but have a dedicated server installed on an Intel Atom micro ATX - so it's about 25cm x 25 cm, with a laptop 1Tb drive in it, very good on power and Squeezecentre has a plug-in to shut the server down and wake it up when required or not in use. Much better performance than running on a NAS plus you can upgrade it whenever required.
Then install http://vortexbox.org/ this installs Squeezecentre, plus a load of other stuff, lets you rip disks direct from the server, music or DVD's to FLAC mp3 or whatever. This is all free Linux based.
It's literally a case of putting the cd in and away you go.
Vortexbox really was the missing link in my previous Squeezebox setup.
Posted : 05/01/2012 1:39 pm
I,ve just come across [url= http://www.audiosanctum.co.uk/vmchk/Music-Server/Cocktail-Audio-X10-Music-Server.html ]this[/url] which looks like it might be pretty good.
Posted : 05/01/2012 2:20 pm
I wish... http://www.cyrusaudio.com/products/streaming-music-players
Posted : 05/01/2012 2:31 pm
Page 2 / 5
