Some road bike ques...
[Closed] Some road bike questions
 Taff
[#1974731]
I'm currently watching fleabay for some bargains and have found some retro road bikes which I quite fancy doing up and using for the daily commute. Not owned a road bike in 15 years sand can remember jack about them so I'm hoping you can help me.
Rear hub spacing - is this like mountain bikes ie a standard width so when shopping for a new back wheel I don't have to look for a particular one that is as rare as rocking horse poo?
Down tube shifter - I don't mind these but is there a cable stop that can be retro fitted to the braze ons so that I can run STI shifters?
I'm presuming as well that road bike steerer tubes are still 1"
Posted : 09/09/2010 2:43 pm
Rear hub standard is 130mm. It'll have to be pretty old to not be 130mm spacing
cable stop - yes - standard fitting for cable stop or down tube shifter.
Road bike steerer tubes are normally 1 1/8" now though older ones were still 1" up to 2000ish and more current ones have tapered sizes
Posted : 09/09/2010 2:45 pm
Yes 130mm from late 1980s if not earlier.
STI's com with cable stops that will fit on std braze-ons.
Many steerers now 1.125" but I think decent 1" forks are available.
Posted : 09/09/2010 2:46 pm
Someone more informative than me will come along.
Long road rides are great though, stick with it 🙂
If you are thinking about modernising a 1980s bike, to get sti on will often require a whole new groupset. Pricey. Old 531 frames ride nice though.
Posted : 09/09/2010 2:48 pm
Also, to consider is that Italian frames Colnago, DeRosa, Bianchi, Pinarelo, etc may have an Italian thread bottom bracket .
Posted : 09/09/2010 2:53 pm
 Taff
Without giving too much away it a [rusty looking] [u]1967[/u] Ken Ryall. I may want to a new rear wheel on it with more gear options hence the query.
Posted : 09/09/2010 3:01 pm
Ah, well that almost certainly won't be 130mm OLN at the back - probably 120 or 126 IIRC.
That said, since it'll be steel it may well be perfectly possible to have the rear end 'reset' (read "bent") out so that a 130mm hub will fit - I've done it myself on a 531 frame I had in the mid 90s.
DIY or take it to a frame builder if you're not confident.
Or, find a hub to match but it will make it hard and/or expensive to get parts (eg gears) that'll fit.
Posted : 09/09/2010 3:05 pm
 Taff
Thanks Clubber [and others] I thought that was the case. I may end up having to bend it if it comes to it then.. will just be wierd doing it on purpose!
Posted : 09/09/2010 3:08 pm
FYI - my 1987 Raleigh Clubman frame was originally 125mm OLN wide. I had the frame resprayed in early 90's and just asked the shop that did it to coldset the stays to 130mm OLN as I was going up from 6 to 8 speed at the same time. No problems for a good LBS. Ken Ryall ceratinly sounds british so should be ok for BB threading.
Have a look at the classifieds on Cycling Weekly site - there was a really nice mid/late 80s Bianchi in Columbus steel a couple weeks ago.
Posted : 09/09/2010 3:13 pm
My 1969 is 116 though 120 5 speed would be more common. That means respacing or sourcing period parts. Or make it fixed.
Posted : 09/09/2010 3:16 pm
Narrow bars from that period are horrid, 40cm feels like youre gripping the stem, fine in the time though.
Posted : 09/09/2010 3:20 pm
You can still get 1" carbon forks - I just bought some for my early 90's 653 frame. Moving to a carbon fork, aheadset and wide bars gives even older steel frames a very modern feel.
Spacing is your biggest problem. 120 or 126 OLN from 5-7speed bikes will give you the biggest headache to get respaced to 130OLN.
Posted : 09/09/2010 3:54 pm
Agreed re fork, though a bit pointless onthat frame IMO.
Re-spacing is a doddle!
Posted : 09/09/2010 3:55 pm
I'd take a guess at a 120mm rear. My 1989 was 126mm and went from 6 speed to 7 and 8 at 130mm without a complaint. Just did it, no shop or framebuilder. A nice, cheap short quill stem was surprisingly hard to find when I last looked. It'll probably be 27" wheels rather than 700c too, you'll need a long drop brake caliper if you want newer wheels. I've got some nice 27" wheels in my shed actually.
Posted : 09/09/2010 4:12 pm
I have just done the same, bought an old steel lugged road frame off ebay to do up and use as a commuter. When I got the frame I measured the drop out spacing and found the rear was 126mm and the forks were around 91mm. I had thought that everything road was 100mm front and 130mm rear. I did some research and found some helpful info here [url= http://sheldonbrown.com/frame-spacing.html ]Sheldon Brown Frame Spacing[/url] Looks like the frame and forks can be adjusted with a bit of 3x2.
Posted : 09/09/2010 4:27 pm
Stever 27"? not five speed are they 120 spacing?
Posted : 09/09/2010 4:30 pm
Some older forks only take axles with flats on the thread, so you might need to get your file out .
Posted : 09/09/2010 4:37 pm
Mm, 27" is slightly different to 700c is all I'm saying and tends to be found on older Brit road bikes. 5 speed would be 120mm I think. King Sheldon gives it as 630mm vs 622mm 'Bead Seat Diameter' http://sheldonbrown.com/tire-sizing.html
Our man thought this was all going to be easy eh 😉
Posted : 09/09/2010 4:51 pm
God yes, its a fair chance of being a 27er!
Posted : 09/09/2010 5:38 pm
I've been after some 27 x 11/4 wheels in five speed, but looking at the tyre market I don't think I'll bother.
Posted : 09/09/2010 8:44 pm
