Viewing 23 posts - 1 through 23 (of 23 total)
  • Soap flakes – questions
  • rob-jackson
    I have a 400g box of soap flakes. How much for a machine wash of 2 items?
    I know i have to dissolve in water first – how much water/g?
    Could i make up a big (5l) bottle and just use as and when i need?
    druidh
    I just stick a small amount in the detergent drawer. 1/2 cup would be about right.
    PrinceJohn
    I have a question – where’d you buy them? I scoured a couple of supermarkets this weekend & couldn’t find them. Unless I’m looking in the wrong aisle?
    rob-jackson
    ideally i want to make it up into a solution to stick into the ball to go in the drum
    rob-jackson
    boots
    druidh
    Just throw it into the drum with the clothing then. The ball isn’t adding anything.
    rob-jackson
    Just tried your method in the detergent drawer – it took 2 full kettles of warm water to push it through!!
    Gonna try option 2 now – 4l of hot water and a cup of flakes dissolved 🙂
    RustySpanner
    I just mix about half to a cup full with warm water in a jug, then pour it in via the drawer or directly onto the clothes.
    Stir well till the flakes dissolve.
    If the clothes are really, really, fallen-in-a-peat-bog filthy, I’ll presoak them in the bath or in a bucket first with a soap solution.
    You really don’t need to use loads of the soapflakes.
    BEFORE YOU WASH YOUR CLOTHES:
    Remember to run your machine through a couple of wash cycles at 90 degrees to remove detergent residue.
    Couple of old towels to stop the drum jumping out of the machine. 😀
    druidh
    And how much water do you think goes through that drawer when the machine is doing its thing? I’ve been doing it that way for several years and never had a problem. Trust me – you’re over-thinking this!
    rob-jackson
    well seeing as the water through the drawer did **** all …..
    druidh
    You put the flakes in the correct side of course…..
    rob-jackson
    the middle – prewash one side, middle is powder/liquid, right is softener
    shifter
    Two washes at 90 degrees before putting your bike gear in? Blimey that’s an expensive faff innit?
    RustySpanner
    And how much do you pay for posh breathable jackets?
    Would you rather buy new ones every time they get dirty?
    Not a lot in comparison is it? 😀
    shifter
    Just checked – mine does a 95 degree wash! Never knew that, always use 40… I do a 30 degree fast wash before the gore wash 🙂
    Pieface
    Or just buy tech wash
    rob-jackson
    Which is liquid soap
    RustySpanner
    Pieface – Member
    You still need to remove the detergent residue.
    It takes 2 or 3 minutes to mix the soapflakes.
    Worh the financial saving?
    I think so.
    nealy
    It tells you how much to use on the back of the box but…
    measure 30g of flakes into a jug, pour about a pint of boiling water into jug and stir until dissolved, pour contents into drum with clothes and press go on the machine.
    Frankers
    As above 30-40gm dissolved in boiling water then put direct in the drum.
    I tried undissolved in the drawer and it clogged the machine up, i’m using the Dri-Pak flakes
    oscillatewildly
    ….or just buy liquid soap flakes by the same company? = no faffing?!
    cheers_drive
    Is there really that much residue left in the drawer and drum to warrant 2x 90 degree washes?
    If there is that much left then I could put normal clothes without detergent and the residue would clean them? I would have thought that the small amount of residue would get diluted enough by the water and soap flakes so as not to matter.
    Pieface
    Isn’t this just a simple maths / dilution equation? therefore if its 40g per item (for example) and you know you’re going to ‘dose’ your wash with 100ml of ‘formula’ then just dilute 400grams in 1 litre of warm water? as long as you shake it up each time you use it that should now be your detergent free detergent.
    With regards to the residue,i think cheers_drive is on the money.
The topic ‘Soap flakes – questions’ is closed to new replies.
