This one from ebay.
I have and use a Trouty light which is powerful but quite flood like. However I prefer to use both a bar and a helmet light, so I wanted a somewhat spot-like one for my helmet. I’ve been using a commuter light but having a built-in battery it was heavy and annoying – plus it only had a 1 hour runtime on high.
I’ve accquired several high quality batteries over the years which are still fine although the HID lamps went the way of all HID lamps, so I thought a cheap ebay job would be worth a punt since I don’t care if the battery or charger is rubbish. I specifically wanted a small light unit, and I didn’t want it to overpower my bar light so I wasn’t so keen on the Solarstorm twin job that seems the most common. This thing is light enough so it doesn’t wobble around when running.
The light came in a couple of days and I was quite surprised with the quality of the lamp unit. It’s as light as I could expect, nicely machined out of alu and has o-ring seals where needed. The bar clamp is rubber band based like the Lupine ones but you can easily un-hook the rubber band and change it for a different size, unlike Lupine. It also came with a headtorch mounting strap which is pretty small and tight on my big head but pretty secure, and possibly tolerable for longer term wear. Thanks to the bar style fitting though I’ll be using my old Lupine helmet mount.
The downside though is the beam pattern. It’s a pretty small bright spot, with a quite large and evenly spread (but much dimmer) cone. This wouldn’t be so bad (in fact would probably be perfect) if there were a nice gradual transition between the spot and the flood, but there isn’t. I may try and modify this a bit later – turns out lenses are widely avaialble on ebay for pennies so I may attempt to replace the flat glass cover with a converging lens or something.
Anyway having just taken it down the path to check the beam pattern it might work out okay for helmet use. I usually set my helmet light to look way way down the trail, and here the spot is less of a problem of course.
As I was swapping connectors over I measured the current draw. It was about an amp on high and a remarkable 330mA on low!
So I’ll provisionally recommend the lamp unit for helmet use on account of its pleasingly low weight, stupidly low cost and adaptability for running. I’ll see if I can get hold of a really small battery that I can stick in a Spibelt for running use – it only needs to be a couple of Ah.
EDIt hmm.. just checked the specs for the LED on the Cree website, and it says it’s 1000lm at a current of 3A. But I measured it at only 1A so I guess that means only 300lm. However it looks way more than this.
The cable is very very thin indeed and I did wonder if that was limiting current – given the measured current is so much lower than the spec for the lamp – perhaps it is.
