Snow driving questi...
[Closed] Snow driving question.
[#2241774]
I had my first winter of snow driving last year and it's been going fine this year (although we've got some very slippy stuff here).
However, reading this today out of idle curiosity something confused me.
http://news.bbc.co.uk/1/hi/uk/8443690.stm
Stay in a higher gear for better control
I'd thought that the deal was stay in a lower gear so you engine brake and don't use the foot brake? What's the theory behind higher gears? Is this on the flat/uphill so you're putting less power down?
Cheers.
Posted : 01/12/2010 1:24 am
More "grunt" - less chance of spinning the wheels as you accelerate. Most modern vehicles will happily pull away from a standstill in 2nd gear.
Posted : 01/12/2010 1:27 am
high gear means no rapid acceleration, so no wheel spin
Posted : 01/12/2010 1:28 am
So, just the same principle as when pulling off (though I did have some spin even in 2nd tonight) but on the flat/uphill?
Druidh- mine is not a modern vehicle 😉
Posted : 01/12/2010 1:37 am
The other thing to bear in mind is if your vehicle is 2 wheel drive then engine braking will only effect 2 wheels, whereas using your brakes very gently will distribute braking around all four wheels. Meaning it is less likely that you will slide.
Yes using a higher gear will mean that you use less power, as power is directly related to engine revolutions.
Thing to remember in bad weather (& I'd argue all the time) is that a well maintained vehicle without any mechanical faults will only ever slide for 3 reasons:
Sudden/hard steering inputs
Sudden/hard acceleration
Sudden/hard braking
All of which are controlled by you, the driver. Just be very gentle on all the controls and you'll be fine.
Posted : 01/12/2010 5:27 am
The thing that always stuck in my mind from training years ago was being told to treat the controls like they would cost you a fortune every time you used them.
i.e. try not to use them
You obviously have to - but you get the idea
Posted : 01/12/2010 7:18 am
Neither does engine braking have any ABS, so stay in a higher gear and use the pedal brake.
Posted : 01/12/2010 7:33 am
Even on a 2wd drive car you should use engine braking (but not high revs) as much as possible. The brakes are quite insensitive so it can be quite hard to not lock the wheels, once the wheels are locked the car will follow the camber of the road, whether that be sideways or forwards. If only one set of wheels lock then the car will start pointing in a different direction as well.
With engine braking, if the wheels lose grip, instead of being completely locked they will turn slowly as the engine idles. This will give a small amount of control enabling you to keep away from the kerb and steer around stuff.
[i]Thing to remember in bad weather (& I'd argue all the time) is that a well maintained vehicle without any mechanical faults will only ever slide for 3 reasons:
Sudden/hard braking[/i]
Or gentle inputs on snow, or any input whatsoever on ice!
I am dont subscribe to the higher gear school of thought on this one. I much prefer to just do stuff really far in advance. Smoothness is key.
Posted : 01/12/2010 8:28 am
Smoothness is the key
+1
And don't be afraid to keep your speed low, all the ****s behind in 4wds can just sit there fuming
Posted : 01/12/2010 8:44 am
Should people be letting some air out of their tyres? Like we do on our bikes when grip is low...
Posted : 01/12/2010 8:52 am
Effectively the same thing getting into a higher gear earlier for a smoother gradual change rather than aggressive.
Sudden/hard braking
It'll reduce it massively but at times you'll slide even following all those, you need to know how to control it when it does go wrong.
Posted : 01/12/2010 9:03 am
Sudden/hard braking
Err no. Ice on a corner? Too much speed? Changing surface? (Hit a white line when braking for instance)
You can start sliding for many reasons. The trick is to either anticipate it, or know what to do when you do slide.
About 14 years ago I was going to pick a mate up from his parents house just outside Newark, in a small village. I was early so as I came up to the village I'd just backed right off and slowed down without braking. I was under 30mph before I got to the 30mph sign. Just entering the village the road took a gentle, slightly off camber right turn, under some trees. I was trickling along really, but under the trees was pure sheet black ice. Totally invisible. All the rest of the roads were fine, but the trees must have sheltered this section. I hit the ice and with no input at all, I was sliding. Up the kerb and onto the pavement and towards someone's front wall! Luckily the pavement was a bit rough and I got some grip back, so I could straighten up and slow to walking pace before carrying on. I got to his house 200-ish yards away, and was telling the story outside when there was the sound of crunching metal. 3 car pile up......
I was on a neutral throttle, under the speed limit, paying attention and the surface looked EXACTLY the same as all the others that day - A bit wet. No input from me at all, save from a gentle right turn which I'd initiated before I hit the ice..... I've had it once since too, under different circumstances. It does happen!
Posted : 01/12/2010 9:05 am
As above - smoothness is the key and 2nd gear pull-away's are not always practical or the answer, especially when engine management kicks in and causes a surge even at a tick-over speeds.
As for engine braking, spookyb has it absolutely right as there were loads of instances in the past few days (in a front wheel drive car and 4 ton rwd ambulance) where if I hadn't been in 1st gear I would not have been able to go [b]down[/b] hills safely as the abs cut in with the slightest pressure on the brakes.
Posted : 01/12/2010 9:12 am
The roads near my work were snarled up yesterday so almost without thinking took a side road to get around it that I often use, having underestimated how 'steep' one section was.
I guess it's no more than 1 in 7 or thereabouts but was ungritted, little used, and has a 90 deg bend part way down. I stuck it in 1, and idled down with with no problems at all, until in my rear mirror I saw some hafewit coming down behind me sideways. Managed to clear the bend with about 15yds to spare before he went straight on into the gate / post / bank - made a proper mess, airbags and all.
When I went back up to see if he was OK, he was incredulous at how I'd driven down 'as he couldn't brake, couldn't steer, could only slide in a straight line' He wouldn't believe I'd done it completely without brakes.
That's what scares me about driving in this. I couldn't have gone faster and if he'd been 15yds earlier would have hit me instead due to not knowing how to drive in this stuff.
If you aren't sure of how to handle the conditions, pls stay at home.
[edit - staying at home today for just this reason, the other buggers]
Posted : 01/12/2010 9:47 am
 jonb
I wind down the windows so I can hear the sound of the tyres on the road. You can tell how much grip you have more easily.
I find steady and smooth is the key. Anticipate what is coming up and act accordingly well in advance. Sometimes speed/momentum is your friend if you need to get up a hill.
I also find not driving is great. Stick some big knobbly tyres on and take your bike. Much less stress on short journeys. If you are having trouble just hop off and walk.
Posted : 01/12/2010 9:53 am
Jon Taylor - Member
/Scratches head 🙄
Posted : 01/12/2010 9:56 am
 D0NK
I am quite a long way from being an expert on this but I was told the engine keeps the wheels turning so the wheels don't lock, and besides most ABS don't handle snow too well. Or so I hear.
1st gear [b]no[/b] brakes down steep hills is how offroaders do it in slippy mud so I'd assume same applys to snow.
Posted : 01/12/2010 10:18 am
 br
[i]I was on a neutral throttle, under the speed limit, paying attention and the surface looked EXACTLY the same as all the others that day - A bit wet. No input from me at all, save from a gentle right turn which I'd initiated before I hit the ice..... I've had it once since too, under different circumstances. It does happen! [/i]
Had this on my motorbike once, everything goes silent... one of the scariest things thats ever happened to me.
Posted : 01/12/2010 10:21 am
Surely the key is to drive at a constant 22mph, slowing gradually to 2mph to take any corner and touch the brake numerous times on straights whenever another vehicle approaches?
EVEN WHEN IT'S ONLY A BIT WET!!!
Posted : 01/12/2010 10:23 am
ABS IS pretty poor in snow - it just can't cope with so little grip so has a bit of a fit.
Just roll as slowly as you can in a low gear but aim to pull off in 2nd - 1st has a lot of torque and breaks traction too easily. Some autos have a snow function and pull away in 2nd.
As above just be smooth with your driving and expect the worst. Expect a car to come too fast around that icy blind corner, expect a pedestrian to step out in front of you or slip over. Double your expected journey times unless it's all on treated roads - I can guarantee the extra time is a lot less than an insurance claim or worse.
Oh and ignore aggressive drivers and laugh at the fact that they will crash soon.
Posted : 01/12/2010 10:24 am
Well if there was award for biggest poop in a post you'd be second after Jon Taylor.
Posted : 01/12/2010 10:43 am
PeterPoddy +1.
Sometimes there is nothing you can do. Last year was my first year driving on snow. I thought I was getting the hang of it pretty well. I read all the advice I could find, practised a bit in empty carparks, and made several successful trips from Newcastle to Fife in horrible conditions (blizzard, foot of snow, etc).
Then one day I was out for a relatively minor tootle locally. It was cold but the roads were clear and dry. Then it started to snow. Still fine. Heading up a back road, nice and gently, got to a corner, smooth engine brake before it down to around 10mph, nice gentle turn of the wheel: nothing happened. I just kept going straight.
Turns out the run-off from the field at the corner had frozen and formed a nice sheet of ice, hidden under the snow, on otherwise ice-free roads. I sat there for about ten minutes and watched another car do exactly the same thing and slide into the field.
Even the recovery lorry was spinning its wheels and sliding as it tried to pull me out!
Live and learn eh?
Posted : 01/12/2010 10:56 am
it's 'kin useless
I tend to turn off the traction control too until I get onto the main roads & get more grip
Posted : 01/12/2010 10:58 am
Sky News last night showed a woman in Yorkshire in a Discovery who had forgotten that even 4x4's need to slow down, and she'd put it into a lamppost. Thought entered my head whether she'd only bought it after last winter?
No point having the vehicle without the training/skills to go with it.
Posted : 01/12/2010 11:03 am
Here in Eire loads of drivers floor the accelerators and get surprised their low profile-tyred cars slide sideways. I've even seen a Ford Ranger with Goodyear off-road tyres fitted stuck on a hill I drove up in my Pug.
BTW Good day to go shopping, Tesco carpark was empty this morning, loovely!
Posted : 01/12/2010 11:04 am
 Rich
That's one of the things I like about my diesel car, I can pull away and drive with no throttle input from me. Just let out the clutch and the car gently pulls away, with no wheel spin.
I drive down my snow-covered road in 2nd gear, again no throttle input. It works really well.
Posted : 01/12/2010 11:14 am
On the subject of using as high a gear as possible Jackie Stewart has some thoughts on the possible contributing effect of low gear driving in the death of his team-mate Francois Cevert in 1973.
Jackie Stewart's book Principles of Performance Driving.
Chapter 4
The High Speed Technique.
"On the subject of gear changing techniques, I have always believed that you should take as little out of the car's transmission as possible that obviously means gentle, sympathetic changes when going up through the gears, but also by using the brakes to their maximum when slowing down, often missing gears while changing down through the box. Many people think that racing drivers go all the way down through the gears in a six-speed box like a machine gun. But that means you're taking on a juggling act: steering, operating the pedals, blippingthe throttle and using the gear lever like a madman. I always chose to change down by jumping through gears.
........from sixth to fourth to second. Thet applies to wet or dry conditions, although you need to be careful how you do iy in the wet, perhaps eliminating all the down changes, using the brakes to knock off your speed, and then finally slipping from sixth to first gear right at the end. [b]Remember, you are not going to stop any faster by using the transmission. Brakes are made to stop a car, gears are primarily for acceleration. Deceleration was not part of the gearbox's original purpose: don't abuse it. [/b]
Chapter 6
The Road Application.
"Somehow many people think that the better the driver you are, the more gear changes you need to make, both up and down, not to mention changing down as many times as possible when you are braking for a stop sign or a round about. Not so! I'd rather use the brakes first because brake pads are cheaper to replace than gear boxes!
Roll into a corner under braking, even in fourth gear, and put it directly into second gear when the time is right, but not when the car is going to nose down and the rear wheels lock up momentarily while the revs shoot off the clock.
So don't rev the engine violently; change gear early and apply the brakes before down-shift smoothly. The braking comes before the gear changing on the way down, never the other way round. And the brake application again should be smooth and progressive. Before you have even so much as touched the brakes you must consider the way in which you come off the power. Don't come off the throtle pedal abruptly, but ease back on it gently.......
The same should apply when you press the brake. Do it gently and progressively and , before you have finished the braking motion, release the brake again very gently and progressivley, so that you don't feel it coming off.
.....a road car is more softly sprung and greater suspension movement , more roll, more dive and more squat. All the movements are exaggerated compared with a competition car."
Posted : 01/12/2010 11:18 am
t's 'kin useless
Can't turn ABS off in pretty much all cars but yep, traction off (if you have it) is the way forward in snow/ice.
Posted : 01/12/2010 11:23 am
Chapter 4
[u]The High Speed Technique[/u]...
Yeah because what we need out there are people trying to drive at high speeds because they think they can drive like Jackie Stewart after reading a book. 🙄
Perhaps a chapter on driving on snow and ice might have been more useful?
But he's talking about driving and stopping quickly. Surely if you are on snow then you don't want to "stop any faster", you want to stop slowly and smoothly without locking the wheels up.
Posted : 01/12/2010 11:31 am
I took our Mazda 323 out on a mercy mission to the in laws after 5 days of snow / frost. They were running out of food and couldn't get out.
I took it gently and smoothly and was fine, was actually catching a 4x4 up on a long snowy climb!
I made the mistake of wanting to take some photos too, as snow on the IOW is pretty rare. Bascially got myself stuck for about 40 mins, BUT I had a spade in the boot and eventually got free. Then had no choice but go down a very icy road which is about 1 in 5. I'd barely been able to ride up it on the bike a few days before.
Just stuck the car in first, took my feet off the pedals and let it do its thing, i was fine.
As said above do everything well in advance and very gently and smoothly and you should be ok.
Given the choice don't drive.
Smoothness is the key to good driving in any conditions. You can get away with driving like a twunt on a dry road but in any low traction situation smoothness is key.
A lot of sensible advice on this thread: engine brake, stay off the brakes where ever possible, hold the steering wheel like its a baby bird and treat the pedals like they have egg shells on them
Posted : 01/12/2010 11:49 am
I wasn't at all surprised at just how many new car-sized holes appeared in the walls and fences on the A675 last year given the idiotic overtaking etc. The only time I very nearly pranged it was heading over Sheephouse Lane. It had been ploughed and gritted up to the car park at Spitler's Edge and for some reason no further. Seeing tyre tracks, I carried on, but was very quickly thinking it would have been quicker to turn round and drive round than stick it in a ditch. I took the long way back home...
Posted : 01/12/2010 11:50 am
Based on a many years experience and regular refresher training, and that the last 10 years of my career have been based on driving different performance vehicles on a daily basis in all conditions (including a frozen lake & all of last night) I stand by what I said. However, I should've added speed is a large factor, and that the driver inputs are all relative to the speed of the vehicle.
I'd agree with jackie stewart entirely; But also add that a car, especially older cars, will lock up the drive wheels and stall the engine on snow and ice. The brakes are the safest way to stop in these conditions. If you're sliding when braking you're going too fast in the 1st place.
Can someone also tell me what neutral throttle is? Im guessing it means neither accelerating nor decelerating. Unless the clutch is dipped and the engine and gearbox are disengaged from each other, they will always, no matter how subtle, have an effect on each other. The correct technique is to release the accelerator, dip the clutch and steer into the slide. If you found that you still went off you were going too fast. Golden rule - you must always be able stop in the distance you can see to be clear on your own side of the road/lane.
Posted : 01/12/2010 11:55 am
My car's not got ABS either so at least it's doing some things right.
Posted : 01/12/2010 12:06 pm
Just read that back through; sorry don't mean to sound condescending but speed is so much of a massive factor in all aspects of driving, and how a vehicle will behave that most people don't realise it. The sad fact is that a lot of drivers just don't have very good speed awareness or spatial awareness once sat behind the wheel. In fact, many people, when interviewed about their daily drive into work cannot recall one detail. It's like they've done the journey so many times that they're on autopilot and not thinking about the drive. It's a fairly big deal driving, yet many people once the test is passed just don't "participate" in the daily drive.
Yeah, that's what I call it. Backing off the gas is 'trailing throttle' too. 🙂
I love snow. Big handbrake turn in the yard this morning! 😀
Posted : 01/12/2010 12:15 pm
That statement is only true when you have an option of going slower.The last big hill I went down in 1st gear was from a standstill at the top. 1st gear kept the speed down to below 10 mph but with ABS, I effectively had [b]no brakes[/b]
I have also been through various courses and have a done a considerable amount of driving in the Scottish Highlands and the Alps.
Using a low gear to keep the speed down when going downhill was definitely recommended on my last 'blue light' course.
Posted : 01/12/2010 12:27 pm
mildred, looking at your driving cv I'm guessing you've been on skid pans? First time I went on one [pre ABS] I was totally gobsmacked by how [b]aggressively[/b] we were taught to use they brakes to stop 😯
Not your textbook method for driving in snow & ice I know, except maybe for an emergency braking situation.
Another technique we used to use in off-road testing [again pre ABS / Traction Control] was to pulse the brakes whilst throttling gently to mimic what would now be Traction Control 🙂
Posted : 01/12/2010 12:30 pm
And don't be afraid to keep your speed low, all the * behind in 4wds can just sit there fuming
I got stuck behind one of the aforementioned *'s in a 4x4 this morning doing 15mph and holding the steering wheel in a death grip. Slowed down to 5mph for every corner and this was on a dry relatively snow free road. It hadn't been gritted so all the snow had just been pushed to the sides by the vehicles leaving 2 clear dry lines down it.
I love the way my car slides, it actually handles really quite well in snow. The works car park this morning was empty, had a nice play round in there. 🙂
Posted : 01/12/2010 12:34 pm
Cadence braking
That how I still do even with ABS
Posted : 01/12/2010 12:40 pm
Yes, cadence braking but used to reduce wheelspin whilst driving uphill.
Posted : 01/12/2010 1:09 pm
LOL ABS. Wouldn't like to be that guys insurance company.
Avoid touching brakes, steering wheel or throttle as much as possible.
If you have to touch them touch them gently. Caress them like you would a fine women.
Posted : 01/12/2010 1:31 pm
Taking the fuse out does the job on most cars if you don't want ABS.
Posted : 01/12/2010 1:50 pm
In snow and ice ONLY. Otherwise, not good.
Posted : 01/12/2010 3:03 pm
