Sleeping mats
[Closed] Sleeping mats
[#3817960]
I'm looking for some advice on sleeping mats. I've been using an air bed the last couple of years but want something a bit more compact for camping and the odd bivi session. Want something comfortable, full length and relatively compact (doesn't need to fit in a baked bean can!) what do you use/recommend?
Posted : 28/03/2012 8:41 pm
The Vango ones are good quality and stupidly good value.
Last well too.
Not used any others for ages.
Posted : 28/03/2012 8:48 pm
Are the alpkit ones any good?
Posted : 28/03/2012 8:54 pm
go alpkit, very good and fairly cheap
Posted : 28/03/2012 8:56 pm
Alpkit Fat Airic here. Very comfy. Probably larger than you're after, sure their smaller ones will be pretty good as well.
Posted : 28/03/2012 9:00 pm
Exped Down Mat or Synmat. I have both and they are super comfortable and warm. Both have a built in inflation pumps that you use by hand and it only takes a couple of mins or so. Not cheap but certainly the most comfortable and warmest I have come across and still just at compact as a thermarest type.
Posted : 28/03/2012 9:03 pm
 MSP
Thermarest neoair, fantastic mats, not seen anything else that packs down as small or as light. The material they are made from reflects heat back at you, surprisingly effective, I wasn#t sure if it would work before I got one.
Downside to them is I find them a little slippery.
Posted : 28/03/2012 9:06 pm
They're a nice idea, but every single one I've owned has punctured, or suffered valve issues. From cheap ones to expensive ones. I'm back to a foam mat for long term trips and suffering the pain, but at least I know it won't get any worse by suffering deflation. For short and dirty festival style trips, I buy cheap air beds and bring a needle, thread and hardware sealant tube to repair it when it can't take the abuse 🙂
Posted : 28/03/2012 10:05 pm
From what I've read, these are pretty much identical to the Multimat adventure mats and are likely manufactured in the same factory.
http://www.fieldandtrek.com/karrimor-x-lite-mattress-782042?src=google
£28 for a sub 500g full length mat seems pretty good
Posted : 28/03/2012 10:09 pm
Anyone else wondering whether they should be taking durability advice from a "Mr Destructo"? 🙂
Posted : 28/03/2012 10:13 pm
had a thermarest for donkeys years - still use it occasionally if my back is grumbling and I need to sleep on the floor!
Posted : 28/03/2012 10:31 pm
I break things so you don't have to 🙂
Posted : 28/03/2012 10:41 pm
I'd like to try and keep the budget under £50. These were 2 that caught my eye....
Alpkit Base 180 £30
http://www.alpkit.com/shop/cart.php?target=product&product_id=16532&category_id=289
Alpkit Dirtbag £40
http://www.alpkit.com/shop/cart.php?target=product&product_id=16533&category_id=289
The Base 180 packs down smaller but doesn't look that thick, anyone able to comment on comfort on these?
Dirtbag looks nice and thick but would be more of a challenge fitting in a pack hmm!
Posted : 28/03/2012 10:46 pm
Alpkit mats are great (I have one for car camping), but if you get a Thermarest (of whatever flavour) thay have a LIFETIME warranty. I delaminated my old one, sent it back and recieved a new (ligher) one no questions asked.
Posted : 28/03/2012 11:02 pm
Still using my Thermarest I bought in 1997. I'd probably buy an Alpkit if buying again as their other stuff has been great and they are much cheaper.
Posted : 28/03/2012 11:05 pm
My Vango one barely lasted a couple of weeks before leaking. I bought an Exped Synmat for the TransAm and it was brilliant. A bit bulkier than a Thermarest Neoair but a lot quieter to sleep on. I liked the self inflation pump too.
Posted : 28/03/2012 11:09 pm
i have an alpkit "airo" (i think?) and dirtbag, airo is the same thickness as the base so probably similar - it's very much a lightweight does-the-job-but-not-much-more option, hence me buying the fatter one which i use when near a car etc.
fat one is fairly big when packed down, thin one is fairly uncomfortable!
i wouldn't carry the fat one on a bike, but i don't like to carry much at all.
Posted : 28/03/2012 11:13 pm
JeffcapesHop - would you say the dirtbag mat is comfortable to sleep on?
Posted : 28/03/2012 11:21 pm
well.. yeah i suppose so! i mean it's a mat in a tent, it's never going to be the greatest sleep, but it's not bad at all. i was pleased when i tried it, put it that way.
Posted : 28/03/2012 11:24 pm
Same as stevious. My Thermarest delaminated after ten years or so when I left it outside fully inflated in very hot sun. I sent it back and I too got sent a newer prolite model with no questions.
Posted : 29/03/2012 12:07 am
Seems like the Dirtbag is the better option of the 2, just concerned a little that its not ideal size for carrying in a backpack but guess you can't have everything! Decisions decisions 🙂
Posted : 29/03/2012 12:05 pm
You're always going to be caught between weight/volume and comfort. Of course, it doesn't help that the lighter stuff also tends to be the most expensive 🙂
Posted : 29/03/2012 12:11 pm
