Skis....what to get...
[Closed] Skis....what to get?
Is there a helicopter involved?
Posted : 04/09/2011 5:50 pm
 10
That money goes straight into Vail Resorts pockets. Most instructors will make less than $15ph for that day.
edit - lift pass is extra!
Posted : 04/09/2011 5:53 pm
Pretty good DIY guide here too:
http://www.jonsskituning.co.uk/content/category/5/14/34/
Posted : 04/09/2011 5:54 pm
It's embarassing if someone paying nearly $700 for a day of lessons
Are you an ISTD or similar?
Posted : 04/09/2011 6:33 pm
I have a pair of K2 Apache Recons which are a few years old they get used on piste. The new K2 charger is similar but has rocker technology and they are good.
Last year I treated myself to a new pair of powder skis and bought some Line "Sir Francis Bacons" they are 115mm under foot but are not too deadly edge to edge on piste and they are awesome off piste.
I am about 13.5stone 5'11 and I am an OK skier not brilliant but not crap. I used to ski about 5 weeks a year then I did a season in Val D'isere 2 years ago where I got in 90 days skiing.
I am quite happy with the above skis.
Posted : 04/09/2011 6:58 pm
The assumption on this thread seems to be that off-piste means powder or soft snow. Over a typical winter that's far from the case. You're as likely to find glassy, hard conditions as fresh powder and hard crusted snow is common. On steep ice a 20-year-old pair of almost parallel Yetis will beat any modern parabolic ski for avoiding terminal velocity.
On hard wind-blown snow with patches of soft deposits a GS ski is a better option than floppy wide things that will scrabble for grip on steep hard ground. With the wide, parabolic designs you end up with the talon and spatule (heel and tip?) taking the load (and twisting horribly) whilst the patin (the bit under the boot) bounces uselessly in fresh air. Some very parabolic touring skis appeared a few years ago, frightened their users and have fallen from favour. Most of the people I ski with are back on skis with a GS profile.
Posted : 04/09/2011 7:16 pm
Edukator who did you work for in Val ?
Posted : 04/09/2011 7:40 pm
Ski Love, La Daille.
Edit, that was in 87, I've just Googled it and it no longer seems to exist.
Posted : 04/09/2011 7:42 pm
That most have been a fair few years ago ?
Posted : 04/09/2011 7:44 pm
LOL pass in the post 🙂
 dab
some good advice so far ...
as a recreational skier don't get dragged into too wide a ski ( ie 100mm waist plus ) not so great on ice unless you have good technique, also rocker is a friend is soft snow but cuts down the contact in the ice
for the record a few skis i like, volkl kendo, scott mission , fischer watea ( scott / fisher same ski under the skin )
k2 skis are nice, poppy and fun (we have 2 sets in the house )
like bikes demo days are a great way to try before you buy, most euro ski shops have demo stations and nearly all the shops sell the rental kit at the end of the season so can be the bargain of the year if you time it right
Posted : 04/09/2011 7:51 pm
 10
@micheal - that's the going rate at Breckenridge and for that, if you don't request your instructor, you could potentially end up with someone uncertified.
@bunnyhop - I heliskied in NZ for 6 lifts and that worked out cheaper than a one day private lesson at Breck.
Posted : 04/09/2011 8:06 pm
Cheers Gravity. I spotted lots of recommendations for him on Snowheads & he seems to have a very good rep. As he's pretty close I think I'll be using him rather than the DIY route.
Posted : 04/09/2011 8:37 pm
Edukator without being rude your coming across a bit anal with all your Ski set up 🙂 workman always blames his tools and all that....
Hire skis are fine, ok the edges can be a bit crap but that can be sorted in 5 mins with a file. I wouldn't have a clue what edge angle I get them too but it does work, and besides depending on the ski and the conditions, depends what and where should be blunt or Sharp. I agree that hired skis don't always get the best wax, but I just take them back and get them re done if needs be. I've never had a bad hire ski since I stopped racing and hence started hiring.
Posted : 04/09/2011 8:52 pm
Edukator - Member
You forgot to mention the death cookies! 😯 🙂
True out of all weeks I've been skiing I've had very few powder days, i can probably cound those on one hand. Most of the time its icey, cruddy and just generally cut up from everyone elses tracks. Still beats skiing on piste for me though! I only like on piste if its quiet really.
Posted : 04/09/2011 9:20 pm
Well, FunkyDunk, my wife is one of the work(wo)men that use the tools I prepare and she won the French winter triathlon championship on X-C skis I prepared. My son races downhill and has competed in the French championship though is still a long way off winning it. I can't claim great things for myself unless you count age group wins and 6th scratch. We usually manage at least one podium a year when skiing as a team in ski-alpinisme races.
So give a good work(wo)man good tools and (s)he'll do a good job. Maybe if you'd had better prepared skis... .
Posted : 04/09/2011 9:58 pm
grinds the edges (ask for 0.5°/89° if the machine can be adjusted)
As an ex-ski tuner all i can say is the only ski that will turn properly is a non-railed, base filed ski. Don't EVER put edge high skis through a stone. The stone is only there to add structure to the base (think grooves), structuring edges is a very bad thing. If the ski is also edge high it will not turn over very easily and your edge bevel angle will make no difference. Having taught for years (and yes I am qualified), and also taught instructors you can make a 'non' skier actually learn properly on well prepared skis. Flat base (hand file it), stone, edge file and bevel, clean, wax. Done. Unless you damage the base you shoudl be able to keep them flat quite easily from there. I used to go through 2 pairs of skis a season working 6 days a week and skiing 7 for around 43 weeks a year.
Posted : 05/09/2011 12:14 am
Rossignol S86s seem to have had good reviews for being to do anything, eg:
http://www.epicski.com/products/2011-rossignol-s86-freeride-ski/reviews/1637
strangley it has been discontinued and there is no direct replacment - maybe rossi didn't want to see a do-everything ski as that might reduce ski sales.
There are still some knocking about.
The Sultan 85 also seems to have good reviews although not quite so much as a do-everything ski.
I wanted to replace my Bandits and took a punt on the S86s as I have always liked Rossi skis, and nearly always disliked Salomon skis.
Posted : 05/09/2011 10:28 am
Edukator - I was hoping this wouldnt decend in to willy waving but I guess I'll join in... 🙂
I only raced to International standard, and never did that great, however I did hold a FIS licence for 3 years. I also in my time have been a qualified instructor as well. I also spent alot of time with the Bell brothers when I was younger (ok they were not that great either).
IMO and experience the initial prep of a base can make a difference if your racing, but then you need multiple sets of skis to get skis for the right conditions. All the top races would have technicians to do this form them, but come race day the edges would always be fininshed by hand with an edge file dependant on the conditions.
For average Joe Bloggs there is no need whatsoever to get so detailed about base grinds and how to sharpen an edge. Also XC skis are in no way remotely like DH skis.
Although modern skis have made life easier for average skiers, they do unfortunately now make people think they need more than 1 set of skis to get down stuff, I guess like mountain bikes.
Everyone is different but these days I like a de tuned type GS ski, so its not hard work all day, can be used very easily off piste in any condition but will still be ok on ice and piste.
Posted : 05/09/2011 10:47 am
Can I just chip in to say that I am a very average skier but do enjoy it?
Posted : 05/09/2011 10:50 am
I'm particularly fond of the peach or black cherry ones.
Posted : 05/09/2011 10:52 am
I think I may be a little better than average - maybe an expert-average, or advanced-intermediate-average?
Hopefully not average-dd (double-dose)
Posted : 05/09/2011 10:58 am
@deepreddave - lol
A good thread but can we keep it light?[img] [/img]
Posted : 05/09/2011 11:08 am
 juan
Where are you going to ski CFH...?
Considering you won't buy the same skis for different resort/region, I would choose carefully.
If you're going around here, I can point you toward the best skiman around.
Posted : 05/09/2011 11:11 am
🙂 @ yoghurt!
juan, most likely going to be based at Serre Che, possibly other Alpine spots, but hoping to get out to Japan next year (assuming work are paying for flights! 😉 )
Posted : 05/09/2011 12:40 pm
There is only one more to add to this willy waving contest and the STW ski team is complete!
Posted : 05/09/2011 3:04 pm
 juan
well are you driving/flying to serre che?
Can you stretch to Nice? There is someone you may want to talk to 😉
Posted : 05/09/2011 3:35 pm
Waxing and base preparation of skate X-C and downhill skis is identical. The French squads in three disciples have combined their efforts on base preparation which goes some way to expalin the excellent result across biathlon, downhill and X-C. They took their own machine with them to the Olympics.
It's a ski thread, it was bound to end in willy waving, go back to my first quote on ski preparation a few pages back and you xon't go far wrong if you want your ski to be performant and easy to ski.
Have you seen the latest machines NZCol. The old Wintersteiger that just gave a flat base with two possible finishes is a thing of the past. Why would you want an "edge high ski". Edge high is considered a defect solved by grinding the base then dropping the edges by between .5 and 1.5° and then sharpening to taste. Always put edge-high skis through a stone, or bin them.
Posted : 05/09/2011 5:25 pm
Unless you holidaying a whole bunch just rent your skis and look for a higher performance rental.
Most resorts (certainly North America) will rent the latest and greatest ski's.
Invest only in a well fitting boot that will last you for 10 years. A set of skis will be out dated and the next fun concept will be out next year.
Plus, if you buy a groomer ski and get a big snow day, you're stuck with what you have. At least with rentals you can go and swap out your groomer ski for a pow cheater ski and have a blast!
Only 1 week a year and there's no chance you'll get any continuity anyway of your own skis, so you may as well let some one else do the service, storage and not have to bother travelling with them.
/2c
Posted : 05/09/2011 5:52 pm
Just found this and, as by far the best skier here, thought I'd chip in
Unfortunately, too much sense has already been talked. I've used hire skis for years now and It'll be a long time before I consider buying skis again, now that I've ceased dominating the world cup circuit.
(anyone want a pair of salomon x-mountains ? PR8 I think, mismatched bindings, hand-serviced by the greatest living technician)
Posted : 05/09/2011 6:01 pm
So which one of you lot are going to tell us you are also better than Danny Hart? 🙄
Posted : 05/09/2011 6:48 pm
Danny who?
Posted : 05/09/2011 6:52 pm
There are rumours that Chemmy Alcott is going to be on Strictly come dancing this weekend. Shame it's not Aksel Lund Svindal. Swoon.
Posted : 05/09/2011 7:42 pm
 Dino
Julia Mancuso!!
Posted : 05/09/2011 7:54 pm
I do believe that Julia and Aksel are a couple.
Posted : 05/09/2011 7:55 pm
Juan, we fly in to Turin and transfer from there.
Work may well be taking me to the sun-kissed Riviera in Spring, though....
All well avec toi, mon vieux?
Posted : 05/09/2011 7:58 pm
Okay I'll have Lindsey Vonn, you two can have Mancuso and Alcott 😀
Actually I'll take Lara Gutt, I change my mind 🙂 .
Posted : 05/09/2011 8:14 pm
Yes i have seen them and worked on them as well as the Wintersteiger and Montana factory spec machines as well (We actually had a Montana factory machine in our NZ shop). There are a myriad of base combinations available depending on how you dress the stone and what speed you dress it at.
I said you didn't want an edge high ski, the only ski you will ever be able to turn efficiently is a completely flat ski and grinding it flat doesn't work, filing it flat first, then structuring the base on the stone and then finally applying a bevel to the edge is how you should do it. At that point you have a well structured ski, that will take wax, which can have proper turn initiation and a nice edge bevel. Structuring edges and mashing skis through a machine with sparks everywhere is a totally pathetic way to prepare skis (not to mention quite expensive on stones). The heat generated on the stone in a heavy grind (to try and flatten it) makes the base expand with the heat (even with a very high emulsion content in the hopper), then when it cools it tends to contract and make the ski 'rail' again really badly. So base file them and then prepare them properly. I'm not even going to bother willy waving and listing why I believe it should be done like this but all i'll say is we prepared all our skis like that and kept them like that all year and I consistently fouind it easier to teach people on those skis than railed skis. We did blind tests where we used the same ski (model, age and days use even) prepared 'normally' i.e. ploughed through the automated wintersteiger that we never used, and one that had been hand flattened (takes about 5 minutes a pair) then given a light pass to structure it. Even the reverse camber skis should be done like this. Try it, you'll be surprised.
Posted : 05/09/2011 11:23 pm
Let us know what you decide on OP!
Posted : 06/09/2011 12:39 pm
I shall indeed return here! Am planning a mammoth day out to the Hemel Alp as an initial tester day.
Posted : 06/09/2011 1:12 pm
Fast ski's would be good, or those to help you avoid wolves
[url] http://www.bbc.co.uk/news/world-europe-14637701 [/url]
Posted : 06/09/2011 1:17 pm
Volkl Grizzlys then? I reckon a grizzly would have a wolf.
Posted : 06/09/2011 1:18 pm
Going back a good number of years I had some missiles (MSLs) they would have done too - am not up with the latest skiis I'm afraid.
Or ski sticks like Roger Moore had in The Spy Who Loved me may help.
Wolves could be at Serre Che or Le Grave (do they have any pistes there yet?) too from the map of Haute Alpes
Posted : 06/09/2011 1:37 pm
Page 2 / 2
