Hi all. I figure there is no harm in throwing this to the board, as I cant call the RAC man till the morning now (well i could, but there wouldn’t be much point in getting towed to the garage at 19:00)
I drove home this evening, 15 miles ish (i could ride it, and do from time to time but its a tedious run). All running fine. No coughs or splutters recently so no warning at all
Pulled up to the house, and switched the car off. The radio went off with the ignition (which it isnt supposed to do) which i thought was odd. I tried to turn the radio back on (it should come on, even over eco mode as its an aftermarket unit) and it didnt.
Turned the key to ACC, and the side lights and wipers came on (but no radio still)
all stalks are in the off position, so the car has decided it wants them on its own.
Car cranks fine (new-ish battery) but just wont start.
temperature gauge indicates normal running temperature (95degC)
Ive checked all the important fuses (a couple under the dash i couldn’t get to to be fair, so didnt check)
Ive read that a car that wont start from hot could be suffering from many issues, but most of them mechanical, and relatively simple and cheap to replace. (Crank position sensors, Fuel pumps etc.)
but that wouldn’t explain the lights and wipers i dont think?
which makes me think its the ECU.
Possibly a spike in turning the key back to off browned out the ECU? (and radio?)
hope the radio isnt borked, its pretty new! (should have the receipt though i think)
The car is currently cooling down fully. I will give it a go once its cold, but i suspect that the recovery man may have to be called out, and i suspect he will either reset the ECU, or have to tow it.
Boooo!!
any thoughts?
Its an ’05 2.0l HDi, not that that makes any difference i dont think.
