I should have added a third question. If it does break up, why?
I am basically wondering why matter that is bonded together to greater or lesser degrees, will more often than not fragment in travel even if the release rate is the the same across it.
In other words, if I catapulted a lump of jelly at a wall I assume it would splatter in many different drops instead of hitting as an in-tact blob and a single splat.
EDIT: The waterfall is a good analogy. Thanks. Although I would argue that because it is spread out to begin with, and there are unseen obstacles in the water, it doesn’t work as precisely as I want.
