all the plumbers must be fast asleep – bump
not a plumber but fitted a few showers – pretty sure for running off a combi have to fit one that has a thermostatic valve – but hopefully someone can confirm that because means more money
should run well with combi adjacent – remember with a combi the pressure is more or less your mains water incoming so unless that is bad should be fine – think also depends a little bit on how much energy your combi puts out – if it is struggling then the flow rate reduces to get temperature but should still be better than a non-pumped electric
I once looked at buying a pressure measuring tool because of some concerns over distance from the combi and 3 floors down but couldn’t find one cheap enough to make worthwhile for diy – probably an app’ for it 🙁
edit actually £10 at toolstation plus whatever to attach it to – makes no sense to me why not a 1/2″ fitting as could just whip off cold tap or toilet connector and stick it on – that’s why I’m not a plumber
http://www.toolstation.com/shop/p75711
