Still going, although it's had another complete rebuild since this pic -- now has Rebas and SRAM bits and lighter wheels. Still ace
Bike Forum
Show me your.........Santa Cruz Hecklers
Posted 9 months ago #
seriously if you go for the coil. Keep it. Even if you don;t use it straight away. The DHX 5 transforms the older heckler. Even the DHX air appraently isn't ideal for the older heckler compared to a coil. If you want light weight then you wouldn't have chosen a heckler really. They are not heavy it's just imho opinion to get the best out of them strong kit is better.Also make sure you protect the reat trianle well from cable rub. And make sure you run fulllength cables. Had all sorts of problems for normal non full length cbales. Also make sure the mech cable has lots of length. Had all sorts of ghost shifting occur initally although the cable looked fine in length - although basically it was too short
HAVE FUN and post a pic when finished ( unlike me haha)
Posted 9 months ago # -
Heres mine
This was mine (but it's now someone else's):
[img]
IMG_20110620_163849 by martinhallows, on Flickr[/img]
I love mine.
[url=
]null
[url=
]null
Uh oh that didn't work, how do I post pics from yfrog or facebok? Can anyone help!
Linky works go though
Thanks for all the pics and feedback
In terms of build I'm certainly going to go with coil lyriks for the front as I love the set I already on the chammy. I'll keep it coil on the back although I may upgrade the shock depending on how it runs. Can always lighten it up next year if I do decide to do a 24 hr.
The Black Beast by Freester, on FlickrPosted 9 months ago # -
I have only used an air float.. so others may be better. I run air pikes upfront...is fine
Run Lyriks on mine.
Used the RP23 mine came with at first then fitted a 5th Element. Recently re-fitted the RP23 for a comparison and it felt awful. Coil shock went straight back on!
My baby Heckler aka Superlight
Seems to have
gaylordroad pedals on there!Posted 5 months ago # -
And a foot long stem
I'm thinking of buying a Heckler frame. Can anyone tell me if there is a difference between 2009+2011 models? Are the geometries the same? TIA
Geometry the same.
Changes were minimal, pinch bolts on swing arm replaced with wedge bolts and head tube gussets removed. Nothing fundamental.
Cheers jh, just what I needed
Redesigned swingarms because the older ones used to crack and internally strengthened instead of a gusset which made it a bit lighter I think.
oh! Well lets hope mine new purchase doesnt crack then!
Here's one for the old skool people, it's changed a bit since this pic component wise but nothing major.
I'm considering a new frame but really not sure what to go for considering I love this old thing so much!
Shackleton - Member
**** me that's the worst tilted cam pic I've ever seen! You might as well be riding in a car park!
Thanks tho, gave me the LOLs!
Reply
You must log in to post.
