Sorry, I don’t think I have a picture of my Kona Jake The Snake, but I stripped it back to run it as a fixie. I ditched the canti brakes and fitted an old pair of XTR V-brakes with the Dia Compe levers which are V-brake compatible. I used a White Industries ENO hub, which is fine – it allows chain tensioning, and the chainline was also fine with (I think) a single external chainring (48 teeth). I seem to remember fitting single chainring bolts and removing the inner ring. The 48 chainring is fine for road work – I think a 20-tooth sprocket gives a 65″ gear, and a 15 tooth sprocket an 86″ gear. I’ve tended to use the bike as a winter bike with studded tyres, so it’s a bit slow and lumbering on about a 69″ gear, but everything works. I’m thinking about selling it to help fund an MTB, and I’m wondering if it’s worth putting it back to original spec with gears etc!
