Perhaps one of the more peculiar requests on this forum today but I’m trying to identify an old steel Kona frame, it was stripped and resprayed before its previous owner so they have no idea what it once was.
The cable routing puts it at 99 or after but looking at the admittedly low resolution pics in the brochures it looks like they may have changed the top tube cable stops which would help me narrow it down even further. The ones on mine are rounded at the end where as some of the ones I’ve seen have been quite straight.
I think I’ve already ruled out some years and some models based on the dropout design and the tubes are straight not fluted so I know its not one of the top end frames.
These are mine…
I’ll be heading over to Retrobike if I don’t get much luck here.
Mini bump on this, if anyone has or can get me pics on a 2000 Lava Dome, Fire Mountain and / or Hahanna that would be awesome as I think its probably one of those but there don’t seem to be many good pics through google.
Lava Dome had Ritchey dropouts which makes it either a Fire Mountain or a Hahanna (assuming its 2000). As its a 18″ frame I’ll see if I can get anything like a 4.6 or 4.9 frame weight which should once and for all confirm it.
But all this depends on the cable stops matching the 2000 range which I cant really tell from the pics above or any others I can find.
The Lava Dome had cast Ritchey dropouts which would make my frame a Fire Mountain or Hahanna… again, thats assuming its a 2000 which I cant confirm until I get a pic of some 2000 cable stops from either of those 2 frames.
Being that its the base of the range I’m unsure what to do with the frame, its in serious need of attention, was planning on putting a disc mount on and giving it a respray but it doesn’t seem worth it and I dont need another canti mount frame.
Years ago I had Argos add a disc mount to my, still owned, Caldera. It extended its useful life but rear tyre clearance severely limits tyre choice as 1.95” is really the max you could go too.
There was a vague plan to stick a disc mount on it and make it some kind of super commuter / flat bar gravel bike thing for the wife as her hardtail is a bit beefy sometimes but the cost of the modifications and bits to do it up isn’t much different to a new or much newer and probably better bike.
Had it been a nicer model I’d have considered it more but not so much with a bottom of the range one.
I’d be wary of dating a bike based on cable stops. It’s not an item the factory will pay a huge amount of attention to and could quite easily run for a few years or just as likely change during an MY.
shandcycles – I’d be wary of dating a bike based on cable stops. It’s not an item the factory will pay a huge amount of attention to and could quite easily run for a few years or just as likely change during an MY.
Its not so much dating it from the cable stops more confirming all the other stuff, if these match other 2000 frames then everything else also matches making me sure its the right one.
Stedlocks – There’s a chap on retrobike called Anthony, who knows everything about konas……honest, he is the font of all knowledge!
I’ve posted on Retrobike too as someone has mentioned a guy on there knowing everything but he’s not shown himself as yet.
True dat, Saracen and Raleigh are pretty infamous for doing this.
