• This topic has 7 replies, 7 voices, and was last updated 15 years ago by CHB.
Viewing 8 posts - 1 through 8 (of 8 total)
  • Should you pre treat a steel frame with an anti corrosive?
  • Albanach
    As above – any recommendations? Something like Waxoyl?
    lhafty
    I always do using Fluid Film AS-R. And don’t forget to drill a hole in the bottom bracket shell.
    nickc
    It’s completely unnecessary. But if it makes you feel better, then knock yourself out
    Anthony
    Try weighing the frame before and after. Waxoil adds quite a lot of bulk and isn’t needed at all IME.
    sq225917
    Waxoyl is overkill.
    if you wnat your frame to last forever sue soemthing, but not waxoyl
    40mpg
    And dont drill a hole in the BB, as in my experience it kills bearings much quicker.
    coatesy
    One problem with Waxoyl, or similar, is if you get your frame sprayed in the future, then, when they stove it, it melts, runs out of the drain holes and ruins the paint job (saw it happen to an Orange many years back.).
    CHB
    no need to waxoyl or anything. Steel used for frames is not really susceptible to massive corrosion due to the alloy used and treatment of it.
    You have to really abuse a frame for it to corrode in this way.
The topic ‘Should you pre treat a steel frame with an anti corrosive?’ is closed to new replies.
