Shorter stem?
[Closed] Shorter stem?
[#649044]
I'm thinking about getting a new stem and bars, currently have 90mm one.
I read that shorter stems are better so I was wondering what would the benefits of getting a 70mm one? I can't try one beforehand to get the feel, so is it worth doing?
Posted : 20/06/2009 4:13 pm
It will bring the bike more alive, you'll be able to pop up the front end easier - jump hop easier etc, down side is it may feel more twitchy - give it a try, but try a 70 or 80mm nothing shorter, I replaced a 100 with a 60 and the bike wouldn't climb well, using a 70 (or is it 80?) anyway - perfect now!
Posted : 20/06/2009 4:58 pm
shorter stem may also knock the "fit" of the bike out and make the front end wander/hard to keep down on climbs .....
the ammount of times ive seen people be unable to ride a steep climb because they have stuck on a stem because they read about it being"better" in a mag ....
im pretty sure my 120 thomson doesnt hold me back on descents .... (and i do regularly race to prove that )
Posted : 20/06/2009 5:22 pm
I agree with both of the above, which is contrary I know.
However I fitted a shorter stem and found it great. A decent LBS will let you try a stem even if it's just a cheap one to try for length.
Posted : 20/06/2009 5:54 pm
I went from 100mm to 65mm stem and loved it. Hasn't made any difference on the climbs and cornering is now fantatsic. Bike handles alot better now, has a real confident feel now with the shorter stem.
Posted : 20/06/2009 8:54 pm
Yep, changing the stem will make a huge difference but changing it by 10 mm won't be as radical as 25 or 30mm. Obviously.
I now size bikes with a smaller than stock stem in mind 99% of the time, such is the difference it makes, personally I'd happily sacrifice climbing performance for snappier handling.
Posted : 20/06/2009 9:12 pm
Doesn't stem length depend on the head angle? Steep ie 70'plus longer and 68'minus shorter.
Posted : 20/06/2009 11:44 pm
