Viewing 25 posts - 1 through 25 (of 25 total)
  • Shimano's Highly Serviceable Brakes….
  • spock
    I’ve got a Shimano SLX Brake that is leaking from the Lever cap(rectangular reservoir cap) ,well its blowing bubbles from there when you push the pistons back underwater, so is pretty useless at stopping the bike. Anyway ,does anyone know where you can get the rubber diaphrams that go under the cap/lid from? I’m not holding out much hope as i know about shimano’s great brake spare availability….Doesn’t seem a great idea spending £40 on a new lever that could very easily go wrong again
    Thanks in Advance
    rockthreegozy
    Top cap and rubber bit (for Saints at least) is available through Madison (via your LBS)
    jam-bo
    That’s an open reservoir. Just sounds like it needs bleeding and topping up.
    spock
    Been Bled several times, works perfectly first couple of lever pulls, then back to sponge
    solamanda
    Some brakes are designed to allow air to escape between the outer side of the diaphragm and the outside of the lever.
    jam-bo
    Then you’ve got a leak somewhere.
    coatesy
    Perfectly normal for air to escape from above the diaphragm as it expands and contracts with fluid displacement. If it was leaking then you’d have fluid, not air, coming out.
    ahwiles
    obviously i don’t know the full history/condition of your brakes, but i’d expect to see air bubbles from the top cap if i pushed the pistons back in with the lever under water.
    if you look closely you’ll find/see a small hole – it’s there to allow air to move in above the diaphragm – to compensate for the diaphragm being pulled down as the pistons extend.
    it does sound like you’ve got a problem, but this isn’t it…
    who bled your brakes and are they any good at it? (no offence) – if you’re in sheffield i will do it for beer and cake.
    trail_rat
    As above ! – bet your piston seals are weeping. – shimano feckibg suck that thy don’t supply that !
    spock
    Thanks for the replies , Learn something new every day!
    I’ve bled them , i’ve tried multiple methods from syringe upwards, a bottle, pulling lever and open close bleed nipple and bleed nipple closed and pulling the lever repeatedly to bring up the bubbles,
    I’ve had it air free several times, as i said it’d work perfectly for the first couple of pulls ,but then back to mush.
    When i was cleaning them up with the compressor some fluid did splatter when i sprayed in to the lever pivot area(but after bleeding so could easily be overflow) piston seals dont seam to be weeping as the pads didnt have any oil on them but who knows!
    racing_ralph
    why are you cleaning with a compressor?
    spock
    to dry up/clear the crap out of the hard to reach places
    imp999
    Ive just posted about the rubber band on the brake lever technique and this might be apropriate.
    When you bleed you might be flexing the master cylinder seal into a good shape which then gradually deteriorates and lets fluid past.
    Doesn’t help much, I am afraid, as I doubt the seals are available – like everything else in the Shimano brake section of their catalogue.
    racing_ralph
    spock – Member
    POSTED 43 MINUTES AGO # REPORT-POST
    is that REALLY necessary tho?
    spock
    racing_ralph – Member
    spock – Member
    To clean up the brake of water and oil to check for leaks, or are you just being a knob?
    racing_ralph
    No just curious as to why water is an issue in a pivot thats all. How does it check for leaks?
    BTW less of the puerile put downs – makes you look like a 15 year old who has just been beaten by his mate on COD
    spock
    i dont think you understand me, i was cleaning out the brake of mineral oil after bleeding so i could check for leaks without any red herrings.
    To be fair, you didn’t come across very well
    Kit
    Touché! And if you both need handbags, ask The Southern Yeti for a supply.
    DeeW
    My bet would be either a leak at the piston seals, or somewhere inside the lever: not the diaphragm cap (brakes should work perfectly with the cap off).
    I’ve tested for caliper leaks by burning the pads over a gas flame: any oil that’s leaked out will stick to the pads and burn off with white smoke. Burn them clean then put them back in use them a bit then take out and burn again: if white smoke then you’ve blown a caliper piston seal: new caliper time.
    If no evidence of a leak at the piston then either a leak in the lever or a dodgy hose-caliper or hose lever seal. You shortened the hose recently?
    trail_rat
    hold on ,
    is it the rear brake ? are you bleeding it on the bike ?
    spock
    thanks for the replies,
    I’ve tried bleeding both on and now off the bike(swapped the brake for a spare one), Yes it is a rear brake but i haven’t shortened the hose.
    Interested methods DeeW! Will have an experiment tommorow.
    spock
    sorry forgot to add, the brake did have a crash a while ago, bent the lever quite badly in the process ,could have affected it? (it’s a freinds brake btw)
    I think the problem arose (loss of power) while away in a hotter climate, could boiling the fluid a bit cause a seal to go? I’m not talking alp downhilling but i reckon it could boil the fluid of a long downhill track in Mollorca? What are shimano seals like when it oil get a bit toasty?
    trail_rat
    spock i hate to say it but both my brakes suffered the same issue after boiling the fluid coming down the north face path of ben nevis – might well be scrap
    one last attempt …
    fit brake to bike , adjust bike in the stand so the bleed nipple is vertical
    rotate lever to the horizontal
    bleed from the top down
    if this doesnt work i reckon you have weaping seals in the caliper from the heat !
    spock
    Thanks a lot Trail Rat, Been a bugger to diagnose this one, Will try out DeeW’s methods and give your last ditch method a try.
    Thanks,
    Sam
    Pridds
    Good video on Pinkbike about bleeding Shimano brakes. I know you have tried this might be it might still be worth a watch.
    http://www.pinkbike.com/video/170853/
The topic ‘Shimano's Highly Serviceable Brakes….’ is closed to new replies.
