Dear Mr Shimano,
I like your brakes. I have the XT ones on both my mountain bikes and 18 months ago I bought a road bike with the road versions. All the sets use the same pads so I can bulk buy. 🙂
The XT brakes have a hex head screw to hold in the pads (an older bike had SLX brakes which had a split pin). All good and easy to change.
Sunday night, I decided that the back brake on the road bike needs new pads. Easy job, I thought. For some inexplicable reason, the screw on the road brakes comes with a flat pan head with a slot instead of the hex head. Screw is well stuck so straight away the slot gets chewed up and can’t get it undone. 👿
My damaged screw remover had no space and central hole to work in as the head is so thin. Could not cut another slot because of the shape of the caliper.
Ended up riding my best bike to work on Monday. Monday night, cut the screw out very carefully and removed the pads. Then drilled out the screw from the other side. Cleaned up the caliper and fitted a new set of pads using the split pin. Works fine now.
Why fit the pan head slotted screw rather than the hex head?
Is it to save 0.001g?
I think this is the only slot screw on my bike.
God help anyone who needs to change it out on the road.
Servo
