Cheers, pp, I’ll take a look.
PJ – shortening the hoses is super easy, but you will need new insert and olive. I think someone on the other thread suggested the Ribble set didn’t include them. You just:
slide the rubber cover off from where the lever is,
undo the bolt (don’t pull the lever after this point!),
pull the hose out,
cut the hose down to the right length,
pop the new insert in (technically you need the special clamps for this but when I’ve done it I’ve just held the hose and twatted the insert in with a hammer – it goes in nice and snug eventually!),
pop the olive on the hose and then
tighten the bolt back up into the lever (onto and squashing the olive as you do it).
Slide the rubber cover back over the bolt and you’re done. Easy. 🙂
