When changing pads on my Deore brakes (the bleed with a silly funnel type) they seem to be dragging / pads not retracting fully. I have pushed the pistons back fully before fitting (bleed screw removed) but they still seem to be standing 1mm or so proud of the piston body. I can get the pads in just but lever had almost zero travel (3-4mm at end of lever jams brake on hard)
First thought is I have managed to fractionally over full the brake with fluid. Our maybe they need a bleed.
Bite/reach adjusters are set fully out where they should be and no previous issueslike this
The answer is not buy hope brakes (new saddle already this month!). 😆
