Did my xt brakes the other day. Best results I’ve ever had with them. Bled one way from caliper upwards to funnel on the lever making sure lever was much higher than caliper.
Removed the caliper from frame mount and pumped the worn pads out until nearly touching. Then bled them.
Old oil was like mud. After bleed, I prised the pads apart a little, refitted caliper, job done.
Work great. I’ve tried bleeding with a syringe both ends, but always felt like there was a huge amount of pressure to push for some reason and had a syringe pop off several times covering everything. Funnel method works fine if pads are out.
