Viewing 11 posts - 1 through 11 (of 11 total)
  • Shimano 105 11 speed flat bar shifter
  • tootallpaul
    Hey all,
    I’m looking to set up my RoadRat in a 1 x 11 guise as the rear mech, chain and cassette are all reasonably priced.
    However I can’t find an 11 speed flat bar shifter – they definitely make one, but no one appears to stock it.
    Any ideas?
    Cheers,
    Paul.
    simondbarnes
    Do they? Nothing listed on madison.
    Edit: Tell a lie, they do the SL-RS700 but looks like only as a pair. Currently out of stock, expected availability tomorrow though.
    Gotama
    Microshift plus paul components flat bar converter?
    tootallpaul
    £109 for a pair of the rs700.
    http://www.buckinghambikes.com/shimano-ultegra-sl-rs700-flat-bar-shift-levers-
    pair-black.html
    or £59 for an XTR from Evans.
    I assume XTR 11 speed will work with 105 11 speed?
    simondbarnes
    As far as I know it won’t.
    tootallpaul
    ah. Why’s that then?
    Is 105 ten speed compatible with MTB shifters?
    geoffj
    Different pull ratios for road and mtb 11 speed mechs (at a guess).
    simondbarnes
    No
    tootallpaul
    Well, I shall abandon that project then.
    simondbarnes
    If you do revisit it in the future then also bear in mind that your rear wheel will need to be road 11spd compatible to run 1×11.
    tootallpaul
    Well, you completely nerfed that one Simon. I shall get my coat.
The topic ‘Shimano 105 11 speed flat bar shifter’ is closed to new replies.
