Morning all
I get a shed on friday which is rather exciting. Its a big step up from the cupboard under the stairs.
I’m looking for some advice and suggestions for securing the shed, what sort of padlocks, chains and alarms to use.
I intend to reinforce the area around the door with some lenghts of 2×4 running top to bottom. These will go behind where the hinges are and on the other side where the padlocks will be. I could use lenghts of metal instead.
I was planning on padlocks on the top and bottom of the door, the rounded ones if that makes sense?
The screws for the hinges are going to be replaced with round headed bolts that will be double nutted on the inside.
UNder the area where the bikes will be stored I’m going to fill two wooden boxes with concrete that have either ground anchors or D locks in them and I plan to have chains securing the bikes from there. I maybe able to get some steel eyelets to use rather then the d locks/anchors.
I’d also been thinking about alarms, some kind of PIR alarm maybe?
What can people advise for this please?
Cheers All
