Rode last Sunday and had 7 punctures in 2 hours. Ready to go Tubeless.
Running Spesh Captain Sworks 2bliss on front (1yr old), Spesh Captain Control on rear (3yrs old). Wheels are Fulcrum Red Metal 5 (2yrs old). Tires mount easily to rim by hand, no struggle at all – is that the cause of the problem?
Installed rim tape. Then installed tires – bead not seating in rim perfectly, so put a tube in and pumped up to 35psi. Tire sitting perfectly. Deflated tube but bead moves away from rim. Insert Stans valve then seated other side of tire. Pumped with track pump – NOTHING. Tire beads move around really easiy on rim.
Tried with 3x other tires, all around 4 yrs old. No joy.
Took it to LBS and they tried with compressor but still no joy. Air not staying in there.
What’s next?
