Had an alloy seatpost seized in a steel frame which brute force just wasn’t budging and despite not being one for patience or belief in anything over brute force and/or mechanical means I decided I’d give basic chemistry a chance as a last ditch effort.
Slid the seat collar up the post and doused the top of the seat tube at the seat post junction with penetrating spray. Not WD40 or GT85 which are lubricants or water dispersants but Penetrating Spray. I believe the active chemical in drain unblocker (diluted) also works. Anyways, I doused it 2 or 3 times a day, sometimes more, for 4 days straight. Tonight, grabbed the saddle with frame between my legs and managed to free it without too much diifficulty. Hoorah.
This seat post was seriously seized, it wears the scars from where I used grips to try twisting it previously. When I did get it out, it was covered in dissolved rust, and still has rust spots on the alloy. However, it is still perfectly serviceable and will be greased and go back in….and be more regularly greased in future.
Thought I’d share my experience and hope it helps others. Remember, not WD40 or GT85, they’re (arguably) good at what they are but they are not penetrating sprays. In my case I used WD40 brand Specialist Fast Release Penetrant acquired from Halfords.
