oh and probably teaching granny to suck eggs, but make sure you are undoing them the right way. I only mention this by way of confessing a similar half-hour altercation with an old bmx several years ago.
If the bike is built up, I like pulsgas and 'gentle but long' leverage eg big vice and big spanner or finding a way to prop yourself against a wall and using your body weight on the opposing pedal: i seem to have had better results with this way with old seized in bolts than anything 'percussive' as it seems to round off the flats a lot faster. Certainly worked on my car a few times as well as a few pedals, bottom brackets and cranks.
A proper big size/wide jaw pedal spanner isn't that expensive from halfords (its a rebranded cyclo one), you can use the 2 different angles for 'optimum' leverage and will last forever.
