Quick general question about installation…
The shim is a customised USE type with a large flange probably 4-5 mm that will protrude above the seat tube.
There are two options, to install the clamp first and then shim on top so that the clamp operates on the tube completely and the shim flange protrudes above the clamp, or install the shim first and install the clamp on top which will mean a large part of what the clamp is operating on is shim and not tube.
I’m not sure whether I think this matters or not – either way, the shim is acting on the seat post to transfer the clamping force, so is it really a problem having some of the force directly on the shim? It looks better that way…
