Yes, the Wildcat design is for a harness/bag combo rather than a bag. It’s a bit fiddly the first time you fit it but after that it’s only a couple of minutes.
Personally I find a harness with separate bag to be better as you can simply unhitch the bag at camp, use the contents then in the morning repack the bag, possibly under cover if it’s raining, and refit to the harness. In the case of the Wildcat and other harnesses this is either one or two clips. Filling the bag is also much easier off the bike than on.
Edit: More pros for the harness system. With a harness system you aren’t limited to one size of bag. I have an Alpkit 13L tapered Airlok and an 8L Wildcat tapered bag so can choose which suits my intended load. If the bag gets damaged then I only have to replace that and not the whole system. YMMV of course.
