i’d have thought it would be the one you need – i ran it with xx crankset, which has the 2 rings in the granny and middle position, so if the frm is the same then you’d be good to go (9 vs 10 speed makes no odds for a front mech).
it is the top pull, high clamp version – you need the high clamp to avoid fouling the bottle cage bolts on the scale. I’ve (finally – after an hour’s searching!) found the box it came in…CRC are doing them with 25% off for £80 – mine is pretty much new, you could have it for £50 posted.
it weighs 110g 😀
you might be able to find a dura ace that fits the bill of 38mm clamping as the scott addict roadbike also used the fatter seattube scott favour IIRC.
anyway, stephenroundhill AT hotmail DOT coDOT uk if you’re interested in the xx.
