Set about doing a service on the seals as per the Mojo video instructions. Unfortunately my assistant inverted the forks and all the fluids came out. I have checked various online resources to see about replacing the fluid and all suggest doing the damper side from the top, except one on Pinkbike that showed it from the bottom.
Questions are:
Can I just pour fluid in from the bottom?
If not how do a I get the ock out device off the top of the leg, videos refer to 3 small grub screws which my fork doesn’t have (2010 32 Float RL).
Finally do I need to take the top off the airside and put the suggested 5ml of float fluid in the chamber or is this only necessary if the innards have been extracted?
I do have plenty of the correct fluids and know the volumes from the Fox manual.
