Viewing 2 posts - 1 through 2 (of 2 total)
  • Scary bar mounted light action………
  • andyrm
    Holy mother of god…….. Just ordered one of these retina melting beasts as a new front light.
    All in, including batteries and charger was £73 delivered. A little bit bigger than an Exposure Maxx D at 14cm long and 7cm diameter, but uses 5 XML T6 diodes to give a claimed 4000 Lumens…… Even if it’s half that, for this price it will be insane value. 2-3 hour run time too which experience tells me is about right.
    http://dx.com/p/fandyfire-5-x-cree-xm-l-t6-4000lm-5-mode-white-light-flashlight-dark-grey-4-x-18650-146528
    Got to make a little bar mount up – thinking I’ll just modify a standard bar mount from something else.
    Will keep you all posted once it arrives!
    Northwind
    Be interested what the beam pattern’s like… I’ve got a similiar 3xXML “torch” and tbh full power is just too tight beamed. Works reasonably well on low, though. Going to see if I can improve that a little.
The topic ‘Scary bar mounted light action………’ is closed to new replies.
